I have purchased two replacement batteries for my Samsung N150 Plus Notebook and neither fit properly into the PC. There are two posts on the battery that slide into a locking mechanism on the PC. Unfortunately, the replacement batteries would not fit snugly and therefore, will not lock in place. I confirmed I ordered the correct battery, but neither would fit properly.
Be very carefull of aftermarket batteries (cheap), get one from a reputable dealer. If you have a issue you can return it try here: http://www.amazon.com/Samsung-NP-N150-PLUS-Battery-4400mAh/dp/B006YZVOK0 Some cheap Replacement batteries at best will not work properly/long, at worst can be a fire hazzard. Never leave a laptop with battery inserted unattended.
SOURCE: battery fully charged but still shutting down when disconnected from mains
New batteries have been sitting on the shelf for possible a long time. These batteries need to be cycled quite a few times before they reach their full amp hour capacity. The batteries need to be charger to 100% and then discharge to nearly zero. Do not half discharge and the charge to 100%.
SOURCE: dell Inspiron works on battery only. No AC, no charger.
get a volt meter and be sure the power is coming to the plug, you may have a broken cord. if the problem is not there see if you have a setting in the bios for dc only. some older dells have a bios setting for the power settings in bios.
SOURCE: HP PAVILION DV5000 NOTEBOOK BATTERY LOCK TABS BROKEN OFF
You can take it to any HP service center. They'll replace it free of charge if its under warranty and does not have any physical damage.
SOURCE: Charging power cord doesn't fit snug therefore
Is this the original power adapter, or a replacement. If it's an original and you're having this problem, then you're probably going to need to get the female DC Jack on the motherboard re-soldered or replaced. If your power supply\adapter isn't the original one, then it could be that the replacement you got is not the correct replacement for your laptop. It could still also be that your female DC Jack has gone bad and needs to be re-soldered or replaced. Those are the 2 most likely reasons for your problem of the battery not charging.
