Question about Boating
Have a 1985 90hp Johnson. can i eliminate the oil tank?
Posted by George on
william moore
    Novelist:
  • 184 Answers
Just mix oil in the gas and go for it. did it on VRO, all the time.
Posted on Nov 29, 2012
Hi i have a 1984 25hp johnson with a miss, and a kick like a horse.compresson exellent new plugs and coils. thanks
Spray clean the carb(s). Put in fresh gas and oil. Run Johnson cleaner in tank of gas.
Mar 05, 2018 | Johnson Boating
Have a johnson 200 hp ocean runner.carbs have oil in fuel when i let the motor run for abouy 5 minutes the low oil alarm starts beeping.
Check if your oil feed hose isn't bent or cracked.
It' a sign the oil from your tank couldn't get to the engine fast enough...
If it's a 2 hose oil tank, check if your oil tank cap is wel sealed.
May 23, 2017 | Ocean Boating
Johnson 115 V4 no push at low revs and no oil alarm at hi revs
Good Morning George,
First Thing To Do Is Use Pre Mixed Fuel Until This Problem Is Solved Or Engine Damage Could Be The Result.
Pre Mix Fuel -Oil Ratio Is 50:1
Have You Tried Priming The Oil With The Primer On The Oil Tank Supply Line?
Is The Oil Tank In The Boat Low On Oil?
Let Me Know If You Have Any Luck!
Cheers
Gordon
Apr 08, 2014 | Boating
1999 Johnson 70hp 2 stroke outboard how can I disconnect the self mixing oil tank and premix oil and fuel myself?
the self mixing use variable rate which is much better then mixing it yourself. why would you want to change it?
Mar 18, 2014 | Garden
Boating Logo
102 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
