Fridge does not power on. Woke up this morning to an E4 error message, when I cut one of the breakers, it changed to an E3 message? Sounds like a blew a fuse or something but both 5V fuses are fine?
Here is a manual for that unit.
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
SOURCE: Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
SOURCE: Dometic RM2652 not running
dometic RM2652 will not run on gas... check light does not come on ... can hear the gas valve click
SOURCE: Suddenly our rv fridge won't switch from gas to
If there is a timer fitted check to see if this is working correctly
SOURCE: dometic RM2862 will not come on at all, no blown
I have the same problem Have replaced the power Modular still Refrig light or anything styill doesn't work. Anyone have any suggestions?
