Question about Konica Minolta Bizhub C220 Color Copier
Bizhub c220 tray 1 problem
When i install the Bizhub c220 the machine is showing tray 1 is empty even after loading the paper. pls advice me
Posted by Karthik Keyan on
  • Anonymous Mar 24, 2014
    How do I reset ITU count
  • Anonymous Mar 27, 2014
    new product
ARUN BORA
    Champion:
  • 241 Answers
Pull out tray and check any paper is jammed is remaining at the back end of that tray
Posted on Jan 30, 2013
5 Related Answers
Anonymous
SOURCE: Konica Minolta Bizhub 920
the copier recognised the paper,but when printing/copying the feeder doesn't pull the paper and on the machine it says paper misfead,open front cover.
Posted on Jan 09, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: I have konica mionolta bizhub pro c500 when i
The problems is into fuser unitmCheck the thermistors,thermofuses,heater lamp and the rapis fuse.
Posted on Aug 05, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: Konica bizhub di1610fp priter constantly gives a
Change the paper size,emter in the user modeor press the Utility key.I have the Minolta Di 1610 (copier/printer) and every function is OK.One toner cartridge is OK for 7500 copies,if you can the setting the user tools.
Posted on Sep 01, 2009
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: in bizhub 500 the machine is showing error code
DRum erase lamp is diconnected or burned out, the lamp is located on the drum unit. turn off then on the machine to see if it will clear code
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 27, 2010
Testimonial: "thanks it really was helpful "
Anonymous
SOURCE: konika bizhub c650 not printing through network
pls can i join
Posted on Apr 20, 2010
Bizhub c220 "! There is an open component"
Check the tray door for broken tab that would tell the copier the door is close. might have been broken or the sensor was knocked out of place bye slamming the door.
Aug 10, 2016 | Konica Minolta Bizhub C220 Color...
Bizhub 600 reads wrong paper size in tray 1
Is tray 2 OK?
Any paper stuck behind the draw. Check the setting off draw one in user mode is it for that size paper?
Apr 23, 2013 | Konica Minolta Bizhub 600 750 Image...
We have a bizhub c220 that keeps wrinkling a3 paper. The engineer blames moisture content of paper but the paper has been in the machine for over a week and the room is bone dry. Help.
Try A4 R position and A4 normal position.If is OK the problem is located in the vertical transport section.If the problem persist the A4 paper the causes is located in 2 section:before enter in the fusing unit or exit to fusing unit.Check the Lower pressure roller and the springs.
Jan 22, 2013 | Konica Minolta Bizhub C220 Color Copier
Bizhub c220 defaulting to bypass tray
means from printer properties it can be set to any tray
if ur using defalut settings it is
set it to a4 paper and tray 1 or 2
Dec 18, 2012 | Konica Minolta Bizhub C220 Color...
How to keep the envelope from wrinkling during printing
Are you using proper laser envelopes? The machine should also be set on envelope mode (When you put your envelopes on the bypass tray the machine should ask what kind of paper you have put in there - just select envelopes).
Oct 08, 2012 | Konica Minolta Bizhub C220 Color...
Minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
Jul 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Settings in HP Printer LJ 4100.
The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper.
Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal.
The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page:
MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT.
The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2.
The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray.
Or the arms on the tray that operate the switches are not moving properly.
You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps.
Mar 23, 2009 | HP LaserJet 4100n Printer
Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Mar 29, 2008 | Minolta bizhub 200 All-In-One Printer
Bizhub C450 error (C-0212)
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
Feb 04, 2008 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta Bizhub C220 Color Copier Logo
518 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
Marvin
Marvin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
