Question about Xitel INport Deluxe
Skipping on playback with Xitel Soundsaver
New, way-fast HP computer. Former setup worked fine. New computer on "clean" or "define tracks" playback, I get terrible skips, double beats, more skips. The support given online and on box to zap e-mail is just plain false. I've even tried to call Australia for help. This was not cheap software and I can get no support for a major problem. Unusable software and I have two, neither works. Help. Does anyone know a valid e-mail to Xitel or are they just telling me to FO? now that they have my $
Posted by Christopher... on
  • Christopher Patterson Nov 23, 2012
    I don't know what else I can say about this fatal flaw in software. Sound coming in is perfect. When listening to assign track names it is garbled. Skips, double-quick beats, repeated instantly lyrics. Garbled and unuseable. Is there a place to put in registration key on installing from Xitel disc? I'm sure not using this software illegally. I paid for it, two, neither works on brand new HP dv7-7000t. Dang nice machine. Former HP laptop, Xitel Inport worked just fine. What's up? I can get no support from the Aussies. US phone disconnected, never answer Aussie phone. E-mail given online & on the box is false.
Ok the manual didn't tell me much I just need to find out how to work the CD player on a sylvania scr4986. Can someone help me. I'd really appreciate it.
Basic CD Operation:
1. Power the unit ON if STANDBY mode by pressing the STANDBY ON/OFF(#3).The default
mode is RADIO,so press the FUNCTION button(#8) to switch to the CD mode.
2. Open the CD door by pressing the OPEN/CLOSE door release button(#9).Inset a CD with the
label facing upwards and close the door.
3. The unit will read the disc and display the total number of tracks found on the disc on the
display
4. To begin playback press the PLAY/PAUSE/BAND button(#1).The first brack on the disc will
play.
5. To pause playback press the PLAY/PAUSE/BAND button(#1) once more.Pressing again resumes playback.
6. Press the STOP button(#2) to stop playback.
7. Use the AL 1/VOL- or AL 2/VOL+ buttons(13,14) to adjust the volume level.
Advanced CD operation
1. Press the FWD/TUN+ button to skip to the next track.Press and hold to fast forward the
current track.Release the button to resume normal playback.
2. Press the REV/TUN- button to skip to the previous track.Press and hold to fast rewind the
Random playback
1. Press and hold the SLEEP/RDM button(#15) either during playback or in STOP mode for 2
seconds and then release.You will see the letters RDM appear on the display to indicate the
RANDOM mode in active.
2. If you enable the RANDOM function in STOP mode,press the PLAY/PAUSE/BAND button
to begin playback.If you enable the function during playback the next track will begin the
random order
3. To cancel the RANDOM playback mode,press and hold the SLEEP/RDM button(#15) for 2
seconds and release again.The letters RDM will disappear from the display to indicate the
function has been cancelled.
Repeat function
1. Before or during playback press the REPEAT/PROG button(#6) to repeat a single track
indefinitely.You will see REP appear on the display when active.
2. To repeat all tracks on the disc,press the REPEAT/PROG button(#6) twice(or once more if
you have already activated the repeat once function).You will see REP on the display blinking
to indicate the repeat ALL function is active
3. To cancel any repeat modes,press the REPEAT/PROG button(#6) once more(if in repeat all
mode or twice if in repeat once mode).The letters REP will disappear from the display.
CD program playback.
NOTE:You can only program a playback sequence while the disc is in STOP mode.
1. Press and hold the REPEAT/PROG button(#6).You will see P01 appear on the display to
indicate the program function has been initiated.
2. Use the FWD/TUN+&REV/TUN- buttons to select the track you want to play in slot No 1.
3. Press the REPEAT/PROG(#6) to store the selected track in slot 1.The display will now
display P02 to indicate your selecting the track for slot 2.
4. Repeat steps 2 to 3 for every track you wish to program up to a maximum of 20 tracks. If you
try to program more than 20 tracks the display will revert back to P01 and will overwrite the
first slot again.
5. Press the PLAY/PAUSE/BAND button(#1) to begin the programmed sequence playback.
6. Should you wish to cancel the programming you can press the STOP button to resume normal
function.
Oct 08, 2018 | Sylvania Audio Players & Recorders
The cd player goes into a "skipping" "playing really fast" mode occasionally. Esp. 3rd track, 1st cd. Always has.
It's having trouble reading the CDs. The thing that reads it could be dirty. But try a different cd. The CD player is getting old and if there is even a small scratch it will be hard to read it. A new CD player would be the way to go
Mar 14, 2013 | Audio Players & Recorders
I get jerky picture on playback on the computer using the flipshare program and any other playback program. It's like it is skipping frames or something. Once it is emailed (compressed) it plays fine. I...
Sounds as if your computer does not have the speed required for streaming the playback fast enough. you could add another gig of ram and look at your processor speed, that may need increasing. Try on a friends machine who may have a more powerful RAM and PCU. If it works on that you need to upgrade in both areas
Jan 05, 2010 | Pure Digital Flip Video Ultra Camcorder
DVD GO FORWARD BY ITSELF
Do you mean DVD jumps / skips forward in playback?
If yes, please clean optical laser lens in player. It sounds optical lens has thin layer of dust and causing ' tracking error ' in playback.
Put CD Lens Cleaner disc in player and press play to clean optical lens by cleaning disc and if problem still exist, need to clean lens manually with good quality cotton bud.
Hope this will solve your problem.
Thanks.
Sep 08, 2009 | Samsung HT-Q100 System
''playback error'' message
There are MP3 files with problems, and when they are buried in the MP3, it causes the player to either skip, go to the end, or give an error.
Search for MP3VAL (it's on sourceforge, a free program) and it fixes broken MP3 files. It can do a whole directory very fast. It fixes file length problems in the headers, problems with the streams, and others. If the original MP3 file is badly mangled, you might end up with a "fixed" file that is missing some portions, but that's not created by MP3VAL (MP3 Validate).
See http://mp3val.sourceforge.net/
Mar 15, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
AS-4000 Transcription Kit - Playback skips as if on f/f
check the playback speed, you can set it from 50 to 200... right beside pac man at the top of program
Feb 18, 2009 | Olympus DS-4000 Digital Voice Recorder
Remote problem
Hi There,
On the front panel:
REV Button (DVD)
Press to view the DVD picture in fast reverse motion
or to reverse playback of an Audio CD.
Press to skip Chapters or Tracks.
FWD Button (DVD)
Press to fast forward the Disc. Press PAUSE, then
press this button to begin slow motion playback.
Press this button repeatedly to change the forward
speed of slow motion.
I hope this helps,.
If not, feel free to conact me.
Thanks,
Mike
Nov 03, 2008 | Emerson EWD2203 DVD Player/VCR
Bad playback
have same problem, get dvd error message "disc error unable to read disc
Oct 03, 2007 | Samsung DVD-V1000 DVD Player/VCR
Loss of Speaker Test, Progressive Scan option, FF/RW Scanning, and DTS Sound
First thing to try, would be to unplug all your equipment overnight to see if the microprocessors reset. If your still having problems , then you have a firmware problem and you should contact the manufacturer to see if its downloadable and upgradeable. Good Luck
Aug 12, 2006 | Zenith XBS341 System
Xitel INport Deluxe Logo
43 people viewed this question
Top Xitel Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Bill Boyd
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
