It's probably the magnetron which some companies provide an 8 year warranty on for parts but you'd be responsible for labor. Unless you have an extended warranty, it's probably cheaper to buy a new one than to repair this one. I tried to look up your model number but doesn't seem accurate. Do a little research, there could be a known defect and the company may help even though it's out of warranty.
Unplug the oven and unfasten the cabinet body, using a screwdriver. The body should be attached along the back as well as along the sides or bottom.
Slide the cabinet body back slightly to clear any internal brackets, then lift it off.
Clean the oven, using a vacuum with plastic crevice attachment. Vacuum the fan and other internal parts, then vacuum the vents underneath the oven, on the back and inside the chamber.
Reassemble the oven and plug it in.
Fill a small bowl with a 50-50 mixture of water and white vinegar, then set it in the oven and turn the oven on high for 5 minutes. When the mixture boils, it will remove stubborn smells inside the vents and loosen food particles on the oven walls.
Wipe down the oven walls with a clean sponge.
