New battery purchased,shows charged, but light flashes amber
Is the battery a exact spec.? Some aftermarket batterys, inexpensive replacements, do not play-well with your laptop. If you purchased from a computer store, return for a replacement. That said, It may be that it's not fully charged or need to be drained and charged, cycle it a few times. Some batteries have to go through a "learning" process. It says fully charged in windows software, right? again, some replacement batteries don't play-well with windows.Its a "pins" thing in the battery connector.
SOURCE: Flashing battery indicator
It means you need to replace the battery. My wife's Inspiron did the same thing. Here is a link to someone else with the same issue, as well: http://west-wind.com/WebLog/posts/365.aspx I recommend third-party batteries from a quality source. They are quite good, and much cheaper than Dell-branded ones. Here's a source for both Dell-branded and third-party versions: http://www.batteries.com/index.asp?N=4294967279+4294967148+4294949141&Ne=25&Nu=p%5Fprodcode Plus, they are having a 20% off sale right now, using coupon code "FREE8"!
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
SOURCE: toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
SOURCE: 1721 Inspiron shows flashing amber, three times, then blue.
The cells in the battery are starting to go bad which is why the light is blinking the way it is.
Once you get a new battery put in there the light will stay blue instead of flashing amber.
