Question about Hoover F7431-900 SteamVac Vacuum
Cannot use attachment when spraying it comes out from below
Just all of a sudden......
First it would not despense soap, so we took it apart to clean the rubber washers etc....
got it all back together and low and behold......
I cannot get the water to spray from the attachment it continues to come out of the main sprayer under the unit.
F7431-900 Hoover shampoo
5 Related Answers
Anonymous
  • 1673 Answers
SOURCE: Permanant water flow
To check the water lines you have to take the top housing off, you may have a water line that came loose. It it is leaking from just under the water tank, there may be a line unhooked there. Check the seal that the tank sits on, it may have to replaced, the other is the diaphram that the tank sits on isn't closing alowing the water to keep flowing.
Posted on Jan 10, 2008
Anonymous
  • 152 Answers
SOURCE: Hoover upright vacuum information
cant help with manual but if i may why would u take it apart theres not much to service but to take the belt off turn the machine over and down by the roller there are a few screws take them out the cover should come off and thats it
Posted on Feb 06, 2008
Anonymous
SOURCE: hoover F7431-900 steam vac brushes wont work
the brushes are activated by suction, my berings and gears froze up, i took it apart, kinda hard to figure out, but not as bad as it looks. i lubed the berings and the gears, then i took an air compressor to the activation fins and let it spin, lubed again then hit it with air again, now works better then new.....GL
Posted on Jul 29, 2008
Anonymous
  • 37 Answers
SOURCE: hoover turbine replacement
first you must remove the dirty water tank then the nozzle window on top of the machine. (this is the clear piece that the dirty water is sucked through.) then remove all 8 screws from the bottom along with the 1 screw on the main housing. after all this the top housing will be snapped into the base at two spots in the rear of the upper housing. when these are loose the housing should be out. you will find the turbine in the front along with 2 more screws and 2 hoses that also must come off. attach new part and reassemble.
good luck!!!
Posted on Sep 24, 2008
Anonymous
  • 14 Answers
SOURCE: Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Posted on Sep 11, 2009
1helpful
Detergent container will not despense fluid
Check that the switch is on autowash and not just on the rinse option. I see that customers do this alot.
7helpful
5answers
9200 Bissell carpet cleaner, water will NOT dispense
My Bissell also STOPPED SPRAYING WATER.
I've owned a Bissell 9200 for a few months. I've used it twice, the last time most likely being around August. I attempted to use it this past weekend and it wouldn't spray. I searched all the help sites I could find and thought the solution was a clog in the heater, which many said was located in the arm. After I took the arm apart, to my surprise, THE HEATER IS NOT LOCATED IN THE ARM OF THE 9200 MODEL.
It's still under warranty, however am not located near a service center so I took it upon myself to try to fix it.
I'm just a single female who ends up trying to fix a lot of stuff herself so, I don't speak "technical instructions". But, here's what I did in the event that it may help someone else.
I unscrewed all the screws that I could on the base. I removed the cover over the motor. Doing so revealed the hoses attached to the soap dispenser. Located closer to the rollers were more hoses. On the same side as the foot lever, above the wheel is the where the HEATER is located.
Being that I was looking for a clog, I unclamped one hose at a time; inserted a safty pin into what the hose was attached to and wiggled it; re-clamped hose afterwards.
The only slight confusion may be with the screws. There are only two sizes. I used finger nail polish to mark where the small ones went.
I reassembled it, turned it on, and it actually started spraying again!!!!!!!!
So that this "blockage" won't occur again, I will take advice I've read about cleaning Bissell's hoses out after using it.
See, taking the thing apart was really nerve racking! Especially not knowing if it would even work after I put it back together.
GOOD LUCK WITH FIXING YOUR CLOG!....you'll probably need to sooner or later.
1helpful
Soap or water will not come out
Several things can cause this.
First thing, I check to see if water is coming out the attachment hose. If it is coming out the hose and not the bottom, most likely you have a clogged heater. The heater is located inside the lower handle and just needs to be taken apart and cleaned out. Fairly simple repair, and it is common.
If it sprays for just a few seconds when you first turn it on and then stops, that's a classic sign of a bad pump, and it will need to be replaced.
If it isn't pumping at all out of both the bottom or the hose, there a few simple things to check. Make sure there is fluid in both tanks. It will not work with one of the tanks empty. Make sure the flat belt isn't broken( there is an access panel on the side of the unit to ger to the belt). The flat belt runs the pump. Both of the tanks have a round rubber gasket that wraps around the valve and they tend to come off and get stuck in the inlet valve of the machine. It just needs to be put back on the tank.
There are numerous reasons why this machine might not pump, but these are a few of the most common ones.
Good Luck
Bissell proheat, not sure of model number no water will dispense
Ran in to similar issue except mine would not spray soap or solution through the floor cleaner but would work through the upolstry cleaner.
I found that there were 2 problems as follows:
1) The heater was clogged with mineral deposits and old soap that I had not cleaned out on a previous use.
2) The Valve that attached to the trigger sticks. (I am currently looking for a new valve)
Since you have soap and no water I your problem probably exists in the bottom of the unit. There are 6 screws to take off the cover.
You will see a hose that come from the soap despenser. It leads to the pump which is located in the front left corner of the unit. You can also trace the water hosed in and out of this pump. Since the hoses are clear you should be able to see any clogg. There is a hose that leads up the handle to the valve and then a hose that comes back down the handle (through the wheel opening) The hose that comes back down from the handel leads to a splitter which devides the output to the two jets.
Once it is apart it is pretty simple.
Hope this helps!!
2helpful
4answers
Bissell Quicksteamer
the problem is that after used you have to run clear water through it. the reason is that once you put it away there is still soap inside the tubes. after some time the soap gets hard and clogs it. in the case of the machines that have the heat the heater is also full of hard soap.
good luck
2answers
Sprays soap, but not water
My Bissell is quite fussy. Sometimes I have to wiggle and push down the tank before the water will start to flow. The water doesn't flow properly if the soap container is low - I fill it with water when rinsing. It has a viewport with a red cross that turns when the water flows. Sometimes just removing that and the white filter below (and putting them back) makes it go. Mine is easy to take apart - 6 screws in the base unit and the top comes off. There are two water tubes going into the handle hinge under where the water tank goes - very easily squished or damaged. Last time the water stopped flowing, I ran it with the cover off and just fiddled around with the tubes and away it went. Maybe it is spraying soap only. The water flows up through the handle to the finger valve and heater. Some people say the heater in the upright/handle gets plugged. I haven't had that apart, but it should be easy to bypass the heater.
4answers
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
5answers
Will not spray
I have the same problem. I took it apart and found that the water pump had leaked and burned out the water pump motor. It's a $20 part.
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Mike
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
