Question about Black & Decker Food Processors
I have a Ronson Pro Duo 500 - Model 8347. The machine has served us very well for many years until a while back the small lip, on the bowl lid that locks into the machine to initiate processing action, broke. I just want to know where I can get a replacement lid from, if at all possible.
  • helen Swendson
    helen Swendson Dec 07, 2013
    I need a user manual and parts list for a Ronson Pro Duo 500, Model 8347. cannot find one anywhere. Can anyone help?
  • Dennis
    Dennis May 07, 2015
    Did you have any luck with the user manual? I also need a copy. I rang the Ronson agent but this model is so old that they don't have a user manual. If so, I would love a copy sent to [email protected], thanks.
Glenn
    Master:
  • 587 Answers
Contact Ronson customer care team at 1300 137 798 or e-mail [email protected]
Posted on May 07, 2015
5 Related Answers
Anonymous
  • 247 Answers
SOURCE: Dishwasher destroyed bowl
A quick Google search using the term "braun K600 spares site:au" reveals an internet trader in Victoria who might stock what you're after. A.
Posted on May 13, 2007
Anonymous
SOURCE: Plastic lid broken
Called Wolfgang Puck production center at 800 275 8273 and was successful in ordering the part for the food processor.
Posted on Apr 29, 2008
Anonymous
SOURCE: The spindle (middle thingie) is broken
I don't know about the little lip you're referring to, but the central spindle that comes up from the base of our KitchenAid 12 cups food processor KFP750WH0 splintered and broke while we were using it. We ordered a replacement motor sleeve shaft part number KA8211849 from the Gourmet Depot for $4.95 plus $3.50 s/h. Removing the broken plastic sleeve shaft was the difficulty; it isn't glued or screwed on but somehow it didn't want to be pulled, pried, or cut off. With the help of our neighbor fix-it man and all four of us working at it with screwdrivers, we got the old broken part up and off. Pushing the new one onto the metal motor shaft was easy, and it was fixed!
Posted on Jan 05, 2009
Anonymous
SOURCE: Broken processing bowl to food processor
I have replacement parts available for the Technque CETOFP263, will only charge nominal fee plus shipping costs. email me or post to ebay seller churkey123.
Posted on Mar 16, 2009
Anonymous
SOURCE: need a replacement part for food processor
The motor is runing, but the blade is not turning.
Posted on Mar 18, 2009
How does the slide lock on the Cuisinard Custom 11 Food Process go back on?
The main important thing if you have an older style machine is to make sure when putting it together that the feed tube from the top aligns with the part of the bowl with the spring, so the button on the base gets depressed correctly. For some, the spring mechanism is on the front with the handle, for some it is opposite the handle... check the base for the tiny button to double check.
If you put the top on backwards it won't work (at least not correctly) -- but what's worse is that you are likely to break the locking mechanism when trying to get it apart... either on the lid, or the bowl, or both. It can be an expensive mistake.
Luckily, bowls and lids are available from Cuisinart... and many times the same bowl/lid was used for different machine numbers (the various models are about the base, not the bowls/lids/blades/etc.)
Dec 15, 2013 | Cuisinart DLC-8S Pro Custom Food Processor
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
Just stopped working
Most often when that model processor stops working it is associated with the mechanisms in the lid and bowl that activate the safety switch that prevents you turning it on when the bowl & lid is not on correctly. The mechanisms are not repairable, the fix is to replace the bowl or the lid or both. A proper KitchenAid service agent should have both in stock, take your complete machine in so that the faulty part can be identified.
Nov 26, 2017 | KitchenAid KFPW760 12 Cups Food Processor
I can't figure out how to use it.. I just want to make a smoothie!
You can get a manual at WWW. euro-pro.com.
In order to use the blender the food processor bowl and lid must be LOCKED in place. Turn the lid on processor until it's locked. Then you are ready to use the blender. Select desired speed or pulse.
In order to use the processor, remove the blender and place the gray lid in its place. It should be locked. The lid keeps the blender shaft from spinning and allows the shaft on the processor to turn.
To remove the processor bowl, gently lift up on the lid to unlock it and then turn it away from processor. Bowl lifts off. That's it! Enjoy!
Hope I have been of some help to you.
Feb 10, 2011 | Bravetti Platinum Pro Quad-Blade Food...
The top cover is broken where the lid makes connection with bowl
I think you will have to look on your user manual at the back and see if you can find an adress there, I think you may have to write to them and ask them for a replacement lid?????
Apr 10, 2009 | Food Processors
Need a manual for Ronson Multi Chef so I know how to use it and what parts I should have
I have access to the 8347 if you want it, because no chance on the 8346 I'm afraid (Ronson don't even have a copy)
Mar 05, 2009 | Food Processors
I have a cusinart pro classic, went to use it yesterday, filled it and turned in on, got nothing. i tried a different plug and still nothing. it is not even making a sound.
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food processor
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
Need food processor lid
The lid-lip on my small Braun processor broke too, damn things can't handle being accidentally dropped by a fumble-fingered me!
I still manage to work it, I just need to manually hold the broken bit in place (so the safety mechanism lets the motor start), or just use another long thin doodah, like a wooden kabob skewer, to depress the lever. Not elegant, and it means you have to use both hands at the same time (one to activate the pulse button, the other to hold the skewer in place), but it works.
Anyone had any luck supergluing the broken bit back on?
Jan 18, 2008 | Braun Food Processors
Food Processors Logo
562 people viewed this question
Top Black & Decker Food Processors Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
