Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
Looking to replace a zinc anode in a rheemglas fury 50 gal hot water heater; model: RDV50F. There is no separate port on top of the tank for it, could it be somewhere else around the tank?
SOURCE: water discoloration. Rhreem serial rh0909ff00279
Brown discoloration is evidence of a rusting or corroded steel pipe somewhere in you plumbing system. Trace the water lines back from the faucet and replace all the steel pipe.
White discoloration is minerals that separate out when the water is heated.
You can change the Anode Rod and it should help. It is not an instant fix, the rod will take a week or two to do its job.
If your water heater is still under warranty, call Rheem, they may replace the water heater free.
Posted on Sep 07, 2010
SOURCE: rheemglas fury model # 41V50
I have a 50 gl rheem the pilot it doesn't stay lite.
Posted on Jul 21, 2011
Sep 25, 2014 | Rheem ruud g100-200 water heater,gas,100...
Sep 13, 2014 | RELIANCE ELECTRIC WATER HEATER
May 17, 2017 | Water Heaters
Jul 02, 2011 | Rheem 81VP6S/430126 Water Heater
Apr 10, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Feb 28, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Jan 01, 2011 | Rheem Water Heaters
Sep 07, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
127 people viewed this question
