Question about Kirby G4 Bagged Upright Vacuum
Kirby g4 stoped working
While i was using my kirby g4 it just stopped working as if some one turned the power of. i checked the fuse in the power cable it's OK but it won't turn on.
Posted by chan_57 on
Kirby bloke
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 88 Answers
Cable has shorted out internally, will need new cable
Posted on Jan 15, 2013
5 Related Answers
Anonymous
  • 438 Answers
SOURCE: I was vacuuming my car and the Kirby G4 just stopped
Greetings from GoVacuum,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
If the cord tested ok, then there are a few other things that may have gone bad. I'd be more then happy to try and help you diagnosis the Kirby further. Please just request a repair clarifiaction here on Fixya with further details.
If this helped you figure out the problem, please rate my repair as helpful. I really do appreciate it, thank you.
Chris J.
Posted on Mar 21, 2010
b0sslady2001
Marci Marple
  • 357 Answers
SOURCE: g4 kirby
Try my troubleshooting guide...
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Marci
Posted on Jul 31, 2008
Anonymous
  • 102 Answers
SOURCE: Kirby G4 will not start
Check the mains socket with something else.
Posted on Oct 06, 2007
Anonymous
  • 7 Answers
SOURCE: Kirby G4 stopped working
maybe the impeller broke, that is the most common reason for '' loud noise''....then you must remember that the kiby will not switch on [ all G models ] if the bag and the front nozzle is not properly attached.....
Posted on May 21, 2009
Anonymous
  • 701 Answers
SOURCE: kirby g4 brush wont turn belt ok
Your belt has stretched or worn so the roller brush cannot turn against the resistance of the carpet. You need to replace your belt. You can get one here:
Kirby G4 Replacement Belt
Posted on Oct 29, 2009
HOW DO YOU TROUBLE SHOOT A KIRBY G4 SWITCH?
can only replace with new switch to see if old one is faulty,
Mar 05, 2013 | Kirby G4 Bagged Upright Vacuum
Kirby g4 tech drive, when plugged won't come on ,is it the motor or something else ?
Does anyone know if there is a reset button on the Kirby G4? And if there is where it is?
Jan 03, 2010 | Kirby G4 Bagged Upright Vacuum
My kirby g4 will not turn on. I have checked the fuse and flex, the switch sounds good. pleas advice
ensure the front housing is properly fitted and the bottom of the bag housing that attaches to the machine, if these are not located correctly the safety switches will not allow the vacuum to start.
Could also be the mains cable, any damage may not be visible on the outside.
Or the motor brushes may be worn out, you will need a professional repairer for this.
Oct 05, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby stopped working
Here is a guide to diagnosing a problem with your Kirby. I would imagine that your power cord has a short in it or the carbon brushes need replaced. You may want the take a look at my guide for replacing the power switch as well to make sure that it was hooked back up correctly.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps...
Marci
Jun 15, 2009 | Kirby G4 Bagged Upright Vacuum
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
G4 kirby
ensure the safety switches are made properly by making sure the front brush assembly is fitted properly, you will see a tag that enters the machine making the front switch, secondly make sure the bag bottom housing is on properly and fully rotated so that its tag makes the switch on the side.
The only fuse is in the plug (UK).
Common fault is the mains lead broken internally, unplug from the side of the machine after removing the little cover where the wire goes in. You can use a kettle lead to test the hoover.
If this does not cure it most likely the motor brushes are worn.
Jul 24, 2008 | Kirby G4 Bagged Upright Vacuum
Oct 06, 2007 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
Gerry Harvey
Gerry Harvey
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
