Hi - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Start range, if it does not turn on then the temperature had tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC and I would suggest contacting a professional to move forward accurately.
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
SOURCE: frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
SOURCE: Frigidaire self clean electric stove 'f9' message
looking for lower element for Frigidaire ElectriClean Wall over
SOURCE: self clean lock
Hello there:
Normally every body gets this almost right by cutting the power but there is a trick to this it can be done in 2 different ways depending on the unit
First unplug the unit and wait 15 -30 seconds then plug it back in and wait for 15 to 30 seconds then unplug it again and repeat this step 1 more time then upon the final plug in wait for 5 min and then unlock as you normally would.
now on the newer units the trick is to let it stand unplugged for 1 hour to allow the internal reset device to reset the appliance then plug it back in and then wait 5 min and you should hear it automatically unlock the appliance or you cn simply unlock it as you normally would
BUT REMEMBER DO NOT TOUCH IT FOR THE 5 MINUTES AFTER THE PLUG IN STAGE OR YOU WILL HAVE TO DO IT ALL OVER AGAIN OK
Hope this is very helpful for you please keep me posted on how this is going there is still more that i can show you but i wanted to start with the basics ok?
Best regards Michael
SOURCE: f9 code comes on frigidaire stove when self clean
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#!#
The best thing to do is not use your self cleaning feature....
Whoever invented that has caused way more problems then it solved...
It is a featured designed pruely to sell product because people are inherently lazy and because it burns up good products and then they get to sell more...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
