Heat Pump, yes. Heat strips, no. A heat pump system that uses electric back up heat needs at least a 2 heat/1cool thermostat. It will have the options you need for your system. Unfortunately, your Honeywell will not work. Sorry, hope this helps!
Posted on Nov 23, 2012
SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Posted on Dec 07, 2007
SOURCE: Honeywell Programmable Eletronic Thermostat model RTH230B
There are so many products, we cannot help without the model no. Try typing 'Honeywell programmable electronic thermostat' into google and searching for an image of your thermostat, then get the model no. Then you might be able to get some help.
Posted on Dec 23, 2007
SOURCE: Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Posted on Nov 25, 2008
SOURCE: wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Posted on Jan 05, 2009
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
Nov 18, 2015 | Honeywell Heating & Cooling
Feb 05, 2014 | Honeywell PRO 4000 5-2 Day Programmable...
Nov 08, 2013 | Honeywell TH3210D1004 PRO 3000...
Dec 11, 2010 | Honeywell Electronic Programmable...
May 09, 2010 | Honeywell Programmable Thermostat Heater
Jun 30, 2009 | Honeywell Electronic Programmable...
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Jan 24, 2009 | Honeywell Electronic Programmable...
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
338 people viewed this question
