Everything apart from drum turning we can hear clicks that would normal set drum turning but nothing happens
SOURCE: Hotpoint WMA 22 drum not turning
Hi, common problem with this make of machine but easy to repair. Take off the lid and make sure it is un plugged from the mains...... You will need a pair of hook nose pliers to remove the carbon brushes from each side of the motor. They should be an inch long if not there is your problem.. Just replace and it will run.
Let me know how you get on..........
SOURCE: No drum action from my Bosch Maxx for Kids
Hi, How old is your maxx? Have you ever experienced this before?
This is quite a common problem and can be sorted quite cheap to. You will need to take the back off depending on which model you have to access the motor! Take the motor off and then we can sort the problem.....
Get back to me....
SOURCE: My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
