While iam playing the video in windows media player the video is playing but the sound is not coming . other players are also not working pls help me
SOURCE: Audio and Video (Windows Media, Real Player, and player software) freezes up
Dell Latitude D620 what anti-virus you install this pc?
if ther an antivirus program just configure your realtime setting.
SOURCE: Sound problem
As it gives the message that the drivers are not installed. I would recommend you to download the latest driver and install the same and your issue would be resolved.
I have given the link below where you can download the driver from.
Select Model to Download Driver.
Do Let me know what happens.
Regards
sammy
SOURCE: sound and image, missing codecs
You have to first download K-Lite codec pack from here....
http://www.softpedia.com/get/Multimedia/Video/Codec-Packs-Video-Codecs/KLite-Codec-Pack.shtml
install it ...
SOURCE: windows media player will not play a cd or any music
Ok. Well then all you need is to update your drivers. There is software
available to do this for you, but you will have to pay. This makes life
easier, but its not necessary. If you choose this option, I recommend uni blue driver scanner.
You
can also use the device manager to update your drivers. Follow the
steps provided before to reach the device manger but this time, right
click on the unidentified devices and select update drivers. A new
window will open prompting you to either look for drivers online or in
a chosen directory, search online. In my own experiance, I've noticed
this methoded usually doesn't give the best results.
If you can
find out exactly what the unidentified devices are then you can search
for the drivers online at the manufacturers website.
If this
is a company distributed laptop or desktop (e.g. HP, DELL, Sony), well,
then your in luck, you won't have to know the names of the devices, as
long as you didn't change any hardware in your computer.
For example, I am using a Compaq Presario F761US notebook pc.
I
would go to www.hp.com > Support & Drivers > Download drivers
and software (and firmware) > and search for my product. Compaq
Presario F761US. Then select my operating system, Vista.
This is the result.
As you may have noticed, the drivers for all of the hardware that come with this pc appears on the page.
You
can do the same for your laptop or desktop or if you provide the
Manufacturer and the Model Number, I can provide links to the drivers
you need for you.
A note on the recovery disk, that suggestion
will work as well if you have not altered the hardware, but it will
restore everything to the factory default, thus you will loose all of
your data. Use this option if you don't mind loosing data and if your
having performance trouble.
SOURCE: asus model k40IJ. playing movie in media player no
First you have check no yor BIOS that your internal sound card is enabled or disabled and then check on your device whether it's being detected
If your system detects it then you need drivers for the sound card
here is the link if you are using Xp
http://support.asus.com/download/download.aspx?SLanguage=en-us
The computer requires motion picture enhancement programs to generate continually. For example, networking streaming picture enhance mentionable are flash player, shockwave player, direct x players or active x players. Search the internet to acquire and download comparable media codes mentioned to achieve motion media experiences. Once downloaded, flash player would acquire the entire media to broadcast continually also called streaming without breaks.
