Question about Nespresso Le Cube
Nespresso Essenza Krups won't puncture - Nespresso Le Cube
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Posted on Aug 30, 2009
Anonymous
SOURCE: Too little coffee
1080p60 is a genius!
he is correct. the owner's manual gives you the impression that it is a three step process: 1) turn machine off. 2) push large coffee cup icon. 3) turn machine back on. BUT it does not make it clear that after turning the machine off, you must hold the coffee cup icon down WHILE turning the machine on. solved the problem perfectly. thank you 1080p60!
Posted on Dec 27, 2008
Anonymous
  • 21 Answers
SOURCE: Nespresso Essenza - water is not coming out of the spout
Try...Hit the start button then Lift the lever and push back as far as possible and hold for 3 seconds. hit stop button, then close lever. this should restart machine.
Posted on May 08, 2010
Anonymous
  • 21 Answers
SOURCE: water not coming through nozzle of nespresso essenza
I have had this issue. I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
Anonymous
  • 21 Answers
SOURCE: When you press the button for a large cup of
You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. The small cup that you are currently getting was probably set at the factory. Good luck
How do i clear the air bubble in the nespresso machine?
OK fill the tank and only use water press the small cap botton and after 5 seconds stop the machein and do the same again untill the pump gets the water into the system
Sep 17, 2014 | Krups Nespresso Essenza XN 2009 Espresso...
Need krups xp5200 manual
Krups may furnish a manual if you inquire.
Jun 18, 2014 | Nespresso Essenza C100 Espresso...
Does anyone know how to pull apart a Nespresso coffee maker ?
Most expresso coffee makers can be taken apart manually.
Start removing screws, nuts, etc. Take a picture every so often so you know how to put it back together.
See the DeLonghi website to get eerie product manuals. (delonghi.com). Search harder for repair parts and you often can get the sequence of how the parts assemble.
You are right, cleaning the jets is the biggest problem area.
Jan 23, 2018 | Nespresso Essenza C100 Espresso...
Where to buy replacement water tank for Nespresso Essenza C100
I need to find a replacement water tank for my nespresso essenza C100 coffee machine. Mine broke, any ideas where I might be able to find one?
Jan 12, 2013 | Nespresso Essenza C100 Espresso...
How do I get replacement parts for my Nespresso C100 Essenza?
you can find them by searching on amazon. click here Amazon com nespresso replacement parts. Hope this was helpful. cheers
Jun 09, 2012 | Nespresso Essenza C100 Espresso...
My Krups XN2005 coffee machine switches itself off as soon as I try and brew coffee from the pod. Any suggestions?
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
Feb 21, 2011 | Krups Nespresso Essenza XN 2009 Espresso...
Our machine does not puncture the Nespresso capsule - so we only get murky water.
I just had the same problem with my new (less than one month use) Nespresso U. (the top of the capsule doesnt puncture and only water comes through). I called Nespresso customer service and a very helpful man suggested I run water through three times by pushing the top slider open with the Longa button pushed and then closed without a capsule in the chamber. That released the air bubble and now I am enjoying a wonderful cappuccino again! The customer service is fabulous, there was never a suggestion of charging me and I was told that Nespresso will send me a free loaner machine if anything goes wrong in the future that can be readily fixed over the phone. The Nespresso U is the best thing I ever bought.
Aug 25, 2010 | Nespresso C100B Essenza Single-Serve...
Nespresso Krups essenza manual XN2001- Switch broken
The machine is not switching on-I am in India-Tamilnadu-can i get it serviced any where here?
Jul 29, 2009 | Nespresso Essenza C100 Espresso...
Light don't stop blinking .... Nespresso Essenza C100
My guess is that the Essenza is in 'Descaling' state. See section 7 of the essenza manual. To get out of it, hold both the buttons down for 3 secs. The lights will then blink at normal rate for a bit and then turn solid.
Jun 21, 2009 | Nespresso Essenza C100 Espresso...
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Nespresso Le Cube Logo
124 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
NOEL
NOEL
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
