Question about Hotpoint Dishwashers
Hi, I have a Hotpoint Aquarius DWF31 Dishwasher. The dishwasher was put on last night and this morning although it looks liked it as cleaned is has not drained. But now there is no power at the machine. I have checked the fuse at the plug which is ok and also there is power at the socket. Is there a fuse inside the dish washer or any thing else i can check
5 Related Answers
Anonymous
  • 209 Answers
SOURCE: Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Posted on Oct 07, 2007
Anonymous
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
gwshaw71
Glen shaw
  • 83 Answers
SOURCE: hotpoint dwf30 freestanding dishwasher
your leak might be caused by a faulty door gasket.as far as your other problem try turning off the power at breaker for 30 sec. to reset cpu
Posted on Dec 07, 2007
Anonymous
SOURCE: Hotpoint Aquarius DWF31
Hello Burmanator,
I had to call a angineer in the end.If your problem still going on.You can try what engineer did it.Turn the dishwasher on and press the program end button (quick wash and normal wash button in the same time). you should hear a pump out water sound.Wait until finish and display 0 again.Than swich off the machine.wait little bit than turn it on again and press a program button.If your problem is over fload device activated like mine.You shoud hear to begin working and getting water in.
It cost me £40 to bring the angineer in and press these two button.5 min.job.Good luck
I hope this information help you.
Posted on Jan 16, 2008
yalmer
Hjalmer Lamminen
  • 552 Answers
SOURCE: Hotpoint Aquarius DWF31 Dishwasher Inlet Valve
Please verify that the hose screen is not plugged.
3.8k is good.
Did you try putting your hand carefully on the body of the valve to check for the clicking sound/vibration at the solenoid?
If you here/feel something, you may just have a plug-up.
Otherwise if there is no noise and since the solenoid coil checks out, You should also check to see if there is voltage to the solenoid coil.
The solenoid could also be stuck and a few taps could loosen junk from it.
Always observe safety!
If there is voltage, by putting a meter across the coil terminals, then you do have a stuck or shot solenoid and the entire valve/solenoid assembly should be replaced.
Posted on Feb 09, 2008
Hotpoint DWF31 dishwasher went bang mid cycle and mild smell of burning plastic. Still powers on, lights on correct setting but stuck at 77 mins with nothing happening. Water still inside. Any ideas
Sounds like you have burnt something. May have shorted out. Shut it down and pull the plug or could maybe cause a fire. Get a professional to look at it.
Dec 19, 2016 | Hotpoint Dishwashers
Aquarius model dwf31. Why doesn't it clean items in top rack?
If you look at the bottom arm you will notice an extension nozzle that comes up out of the center. If you block that from going up during the wash cycle with dishes then the water will not reach the top. This is what makes the top arm spin.
Dec 24, 2015 | Hotpoint Dishwashers
Hotpoint aquarius dishwasher tablet dispenser not working
Clean it by running a cycle with hot water and 2 cups white vinegar, I suspect you have mineral deposits built up and causing it to stick closed and this causes the problem
Jan 18, 2012 | Hotpoint Dishwashers
I have a hotpoint aquarius dishwasher. although the door shuts it will not lock. Sometimes the door will almost shut but the lock seems to jam. Thanks Jim
Possible that this is a mechanical fault. So you might have to remove and clean the lock with a de-greasing spray and close the door few times as you oil it. this might solve the issue.
Please find help on the link below for tips to repair
Dishwasher
Dec 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
i have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Nov 17, 2008 | Dishwashers
Poor cleaning with Hotpoint NDA300Y 73BA dishwasher
be sure rinse aid dispenser is full ..also ck water level after fill should be almost to bottom of float
Nov 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint dwf30 freestanding dishwasher
Oct 24, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Jan 03, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
157 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
