There could be several reasons why your Panasonic RP HT711 headphones are not working properly with your laptop and TV. Here are some things you can try:
- Check the connections: Make sure that the headphone jack is fully inserted into the laptop or TV. If it's not fully inserted, you may not get any sound or the sound may be very low.
- Check the volume levels: Make sure that the volume on your laptop or TV is turned up and not muted. You can also try adjusting the volume on the headphones themselves to see if that makes a difference.
- Test the headphones on another device: Try testing the headphones on another device, such as a phone or tablet, to see if they work properly. If they work fine on another device, then the issue may be with your laptop or TV.
- Update drivers: If you're using the headphones with a laptop, make sure that you have the latest audio drivers installed. You can check the manufacturer's website for the latest drivers and installation instructions.
- Try a different cable: If you're using a cable to connect the headphones to the laptop or TV, try using a different cable to see if that solves the problem.
If none of these solutions work, then it's possible that there is a problem with the headphones themselves and they may need to be repaired or replaced.
