Replacement Battery for Coleman Lantern
SOURCE: Coleman rechargeable lantern: Charged overnight -
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
It is a coleman retro rechargeable battery powered lantern family size # 5312
