Question about Dell Studio 1737 Laptop
Batery won't charge new battery n plug
Posted by kathy miller on
  • max carson
    max carson Nov 18, 2012
    Is the replacement the exact same type?
Richard Cross
    New Friend:
You may have the wrong AC adaptor, Dell is very picky when it comes to Power adaptors, it must be original OEM Dell for the laptop to recognize it, any after market no name brand even though it has the right specs and is made for your model will power your laptop but the circuit to charge your battery will automatically be closed
Posted on May 24, 2013
1 Related Answer
damneddle
damneddle
  • 1607 Answers
SOURCE: my laptop works plugged in but will not charge the battery
You should do trial and error to determine which is faulty. Try another battery pack and/or another charger.
Posted on Nov 11, 2011
1997grand cherokee inline 6 cyl.good batery & alt. what's causing it not to charge batery ?
make sure all connections are clean and free of battery corrosion is the battery "really"good it might need more water in it they run out sometimes always check the ground areas make sure they are clean and touching bare metal
Mar 15, 2013 | 1997 Jeep Grand Cherokee
Despite of new battery my Asus PRO50 won't charge a 100%
Is it a replacement battery? Are the specs the EXACT match, DC volts and Amps? Some inexpensive batteries do not work well with your laptop, it's a Connector/ pin thing, they don't communicate with the laptop. Try pulling the plug and drain the battery and recharge. Cycle it a 4 times, drain/ recharge. Does your BIOS setup have a Battery Learning section?
Dec 13, 2012 | ASUS Computers & Internet
Lg gd850 low battery when powering up the phone
Please try fully charging it. If it still won't work, it's time for a new battery.
Sep 03, 2012 | LG Cell Phones
Won't fire after charging battery
ef you have alarm. // remuve nicetive wire black ( --) charge your batery and then look doors and boot and masking tape the switch of your bonett dawn then you conect your batery good luck?
May 27, 2012 | 1992 Buick Roadmaster
Batery not save
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 23, 2012 | Cell Phones
Batery will not hold charge for more than a few hours
If the cellphone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 05, 2011 | HTC Desire Cell Phone
I got Nokia N99i chinese version cellular phone with 2 batteries, one battery worked for 3 months & now charging isn't holding & other battery can't charge since bought. How can i buy a new battery...
Men you really got a problem!
ok Try Ebay, if not www.alibaba.com sure you can find the batery there.
Other ways:
the batery its not charging at all?
you can buy a Universal Batery Cell phone carger, these ones got the ability of charge some times baterys whit thiis kind of problem.
Make an adaptation from other batery (just look details as Voltage, amps) sometimes its require soldering directly to your phone :S (pretty extreme)
Oct 17, 2009 | Cell Phones
Dell Studio 1737 Laptop Logo
140 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
