JVC HD-61Z456 Television Logo
Anonymous Posted on Nov 17, 2012
Green screen on any input jvc HD-61Z456 sync m:ng s:ng everything else ok
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Jan 31, 2008
SOURCE: JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
jason
  • 905 Answers
  • Posted on Mar 21, 2009
SOURCE: is my tv a jvc model HD-61Z456 ready for digital switch
yes it is digital ready , just follow the guide here for setup of digital mode http://www.fixya.com/support/p520408-jvc_hd_61z456_television/manual-32932/page-33
Anonymous
  • 25 Answers
  • Posted on Apr 16, 2009
SOURCE: jvc hd -61z456
These guys are correct, you need a new dlp lamp. The lamp # for your particular television model is the TS CL110UAA.
Anonymous
  • 1779 Answers
  • Posted on Jul 09, 2009
SOURCE: JVC HD-61Z456 Television to dark
Most likely a bad Polarizer within the light engine of which you cannot buy. The entire light engine would have to be re-built or replaced and they usually start around $600.00....
Chi Chu
  • 8457 Answers
  • Posted on Nov 23, 2009
SOURCE: HD-61Z456, screen went blank. blue light and
power board it dead,replaced the power board.
How do i update the software on my jvc hd-61z456
Did you bump the lens? Is it blurry on all inputs?
Usually firmware is updated via a usb port
I have a jvc screen TV with model #HD-61Z456..I don't have remote how do I program channels input to watch cable tv
buy a Harmony remote control. You program it on line so it never gets obsolete. You can use it again if you ever get a different tv or add a stereo.
How do I change the lamp in my my JVC HD 61Z456 television
On the link below page 78/79 will tell you how to replace the lamp.
http://books.jvc.com/Download/642587931/LCT1928-001A-A.pdf
Good Luck and please rate 4 thumbs up for the free answer
21helpful
HOW DO RESET THE HDMI INPUT? JVC , HD61Z456.
Set the remote to "TV" and 'VCR". Press the sleep timer once and "0 Minutes" will show up on the screen. Afterward, press and hold the "Display" and "Video Status" buttons simultaneously and then let go. A menu will show up on the screen, then press "#2" on the key pad. A new menu will show up on the screen, then shut the power off. I was told it could take up to 3 times for this to work. Hope this helps.
3helpful
2answers
No red when hooking up component cable for dlp hd tv. Only blue and green colors show on hd component input for charter hd cable box. Are there any internal adjustments that need to be made through either...
Check the red cable this is where the red comes from, you may have a bad cable, maybe use the blue or green one just to see if the red will come through, it can be the cable box or the tv or the cable itself.
JVC AV-56WP74 self check question
Each picture tube (red,green,blue) has a magnifying lens assy that sits on top. On each lens assy is a manual focus adjustment with a wing nut that tightens it. The image bounces onto the mirror and shoots it onto the front screen. If you're not a technician then I don't advise you to do this adjustment. You could touch something in the high voltage by accident.
C-Dog
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
