SOURCE: unlock code for samsung GT-E1230
Check the following service, it works if your phone is locked to a provider from Europe, USA, Canada, Australia or Latin America: http://www.fastgsm.com/en/samsung/samsung/e1230/network-unlocker
SOURCE: how do i unlock the phone lock on samsung gt-b3310
If you want to unlock your phone put a sim from another company then
type *#9998*3323# it will reset your phone. Push exit and then push 7,
it will reset again. Put your other sim in and it will say sim lock,
type in 00000000 then it should be unlocked. Type in *0141# then the
green call batton and it's unlocked to all networks. This code may not
work on the older phones and some of
the newer phones. If it doesn't
work you will have to reset your phone without a sim in it by typing
*#2767*2878# or *#9998*3855# (not tested)
Please let me know if you have any further questions or concerns.
Thanks.
SOURCE: mms settings for tmobile on unlocked att samsung eternity
follow this link and info
SOURCE: HOW CAN I REMOVE WIDGET
I think the Widget in the Home screen is in-built.
Just click the widgets button, you can see the bottom, available widgets appears... just drag and Drop widgets to keep in screen and remove from screen.
Delete your wifi connection from your phone and re-create it.
Entering the wifi key again should clear this problem.
If you dont know your wifi key, you need to login to your router and get it from there.
