Question about DeLonghi RT400 Retro 4-Slice Toaster
To replace element - DeLonghi RT400 Retro 4-Slice Toaster
Posted by jimmy on
  • jimmy Nov 19, 2012
    DeLonghi RT400 Retro 4-Slice ToasterI have been trying to remove the handle where to toast on and off but without success. Any idea how to dismantle this toaster
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Dodge magnum pickup heater wont get hot
test the parts and fix it. God bless you
Test and replace a heating element:
  1. Turn off power at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
Test and replace a high-limit cutoff:
  1. Disconnect power to the heater at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the upper access panel and push the reset button.
  3. Replace the access panel and turn the power back on. If the water is hot, the reset was the problem. If not, you'll need to turn the power off again and reopen the access panel.
  4. Use a multimeter to test the cutoff terminals for continuity. If faulty, replace with an exact replacement part.
Oct 28, 2013 | Water Heaters
Ariston Troubleshooting
follow this test and use the multimeter and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating element(s) and replace if faulty
.Test and replace a heating element:
  1. Turn off power at the electric panel and post a sign warning others not to turn it on.
Oct 27, 2013 | Water Heaters
My tankless RP1P is not heating well the water and is already set at Hi Temperature. What can be done to fix it?
follow this steps and fix it. God bless you
  1. Turn off power at the electrical service panel and post a sign warning others not to turn it on.
Oct 20, 2013 | Powerstream RP1P Electric Tankless Water...
Water heater has barely warm water
1) Test elements, and if elements test ok, then replace both thermostats.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) If you do not want to test elements, then replace both thermostats, and if functionality is not restored, then replace both elements.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Call plumber to do the work shown above.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 16, 2013 | Water Heaters
How do I replace the heating elements in my Rheem water heater
Replace heating elements can be found at amazon, click here and take a look: Amazon com rheem heating element . I hope this was helpful... cheers
Jan 31, 2013 | Rheem 82V40-2 Fury Electric Residential...
I need to replace the lower element on my Bradford White Electric Water Heater. Where can I find the element and directions to replace it?
1) Copy following link for testing steps, and clear steps how to replace water heater element on residential water heater.
http://waterheatertimer.org/images/element-wrench-on-element.jpg
2) Your Bradford White most likely uses screw-in type element
Older models use flat flange type element.
3) Buy elements at local hardware.
Match wattage of new element to wattage that shows on label on side of tank
Jan 03, 2013 | Water Heaters
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Both heating elements in the oven not working. I did inspect the h. elements found no burn. thankyou help
Ok, you can confirm element failuer by testing for continuity with a Ohm meter. A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Another reason, why the elements would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
If the elements show continuity, you will need to replace the entire control board(clock, EOC)..
Jun 01, 2009 | Frigidaire Kitchen Ranges
DeLonghi RT400 Retro 4-Slice Toaster Logo
Top DeLonghi Kitchen Appliances - Others Experts
Paul Bade
Gerry Harvey
Gerry Harvey
ADMIN Canada
ADMIN Canada
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
