My Karbon safe has locked because wrong password entered three times.How do I unlock it
If your Karbon safe has locked due to entering the wrong password three times, you will need to follow the manufacturer's instructions for unlocking it. Here are the general steps you can take:
Wait for a period of time: Karbon safes typically have a security feature that locks the safe for a certain period of time after three incorrect password attempts. Wait for the period of time specified in the instructions before attempting to unlock it again.
Use the backup key: Many Karbon safes come with a backup key that can be used to unlock the safe. Locate the key and use it to open the safe.
Contact the manufacturer: If you cannot unlock the safe using the backup key or you do not have a backup key, you can contact the manufacturer for assistance. They may be able to provide you with a master override code or other instructions for unlocking the safe.
It is important to note that attempting to force the safe open or tampering with it in any way could cause permanent damage to the safe and void any warranty or insurance coverage. Always follow the manufacturer's instructions and contact them if you need assistance.
If you're sure the speekers work, it may be ether cause the there is something loose or not conected inside. There is a small posibility that maibe the dvd player doesn't have the right drive or none at all, but if it works with headfones then it's more likely that the speeker is busted so you'd have to replace it. Best thing to do is open it up and look at it and it's conections. See if anything is loose or looks a bit scorched. If everything looks ok, you could try hooking the speeker to something else to make sure they work.
there is no option available for this function in nok 6030,but with a help of damaged headfone you can do this, just cut the wire of your old damaged nokia's headfone form just the pin and then insert only the front pin in the jek of headfone in nok6030 and put the loudspeaker on.... and you get your solution with this little compramise.....
thanks, Rgrds: rajiv kumar 09811461147
