Please help!! I have a Kenmore gas range serial # 362.75970690 and the door is locked shut. We self cleaned it yesterday and can't get it open. I have tried running another self cleaning cycle for 5 minutes, then canceling, shutting off the power, etc. Still won't open. Can you help me??
SOURCE: kenmore electric range 95022
there is a problem with the door lock switch assembley a bad switch or the lock motor or the oven light switch
SOURCE: locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
SOURCE: oven has been cleaning for hours and won't turn off
You will find that the cleaning cycle takes more than 3 hours. Leave it for at least twice that long before you get concerned. When the cleaning is done and the oven is cool it will unlock
SOURCE: tappan electric range pro design model TEF 362
yes you can replace it....you actually get the entire top not just the glass....Tappan is a spin off of Fridgidaire so you would have to get ahold of them to get the top just need to give them your model number....price usually ranges from $200 to $350
SOURCE: Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Shut the door on the oven and turn the "Delay Start Time" knob to the current time. Turn the "Stop Time" knob to 3 hours away from the present time. Turn the "Oven Set" knob to "Clean" and slide the oven door's lock into the locked position. I hope this helps.
