Lands Phones Logo
Posted on Nov 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
House phone says to register HS, see manual what do i do
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Lands Phones Master 102,366 Answers
  • Posted on Nov 17, 2012
Lands Phones Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428697
Points
622693
I assume you're asking about a cordless phone? Cordless handsets need to be "registered" to a particular base station. You wouldn't want your handset responding to your neighbor's calls, would you? Would you want your neighbor picking up your calls?
The manual will give you instructions on registering your handset to the base. If you still have trouble, please repost your question, specifying the make and model of your phone.
How to register hs
It would help to have the model number of the base ( found on a sticker on the bottom of the base ) and the handset (under the battery) but the following works for many models: Press and hold the "Find Handset" button until the "in use" lamp comes on. Press the
"#" key on the handset, then place it on the base... if it is going to work, in a minute or less it will chirp and announce "handset registered". If it shows "registration failed", the base may be "fully populated" and cannot accept another handset: many models are limited to only 5 handsets. To start over by clearing the base registry, press the "Find Handset" button until the "in use" lamp
lights, then continue to hold "Find Handset" until "in use" begins to
blink. Release, then press again the "Find Handset" button for a moment. The base should chirp, and be ready to register handsets again... try again as above until the maximum is reached. Good luck!
My vtech cordless phone says see manual to register what to do
Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Register hs
What make and model phone?
1helpful
Gigaet A495 register HS
You may download a copy of the manual here. The registration instructions are on page 13.
11helpful
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
I cannot get my Vtech LS6204 to register. I have tried everything and the screen always reads registration failed.
I have a 2-handset VTech CS6419 that I had been using w/o problems for months. Both HS were always plugged in and charged. One day I found the base HS would not ring and the screen had the message that I needed to register the HS. Pressing the "find HS" button to start the process only made the accessory HS, not the malfunctioning base one, ring. I solved the problem by 1) unplugging the base, 2) pulling the batteries from BOTH handsets, then 3) replugging in the base and reattaching the battery for ONLY the malfunctioning HS. 4) I then did the registration process again (press the "Find HS" button on the base for 4 seconds, then press the # button on the HS and wait.) The malfunctioning HS then registered! I then reattached the battery to the accessory HS and returned it to its' base. Problem solved!
1helpful
Tried to reregistering
Hi
Please try the following procedure:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Registering phones
I have after many hours found the solution. (Well one that worked for me). I have a Uniden Elite 8855 + 8805 additional handsets. What you have to do is:
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
2helpful
Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
