Question about Kicker Comp CVR 12 x 12 Car Subwoofer
My dual 2 ohm cvr12 kicker are burning on the red dot Connection what can it be and also the symtem hits fine for min then fade.
Posted by big boo on
David Burns
    New Friend:
  • 3 Answers
Check that you have the correct impeedance polarity try turning down your amp gain most of the time its wattage match get as close of a match as possable ohms must be corect for amps specs
Posted on Nov 28, 2012
3 Related Answers
crispin melchor
  • 231 Answers
SOURCE: amp 4 a Kicker S17L7
just make sure your kenwood amp can at least handle a 2ohm stereo load.Most amps now are able to .Your amps manual should list this or go online and check for that model .You basically have 2 subs in one allowing you to use one sub box in stereo mode.And just hook it up like two speakers left and right ..make sure amp has a crossover so that you only get bass at your woofer
Posted on Jul 30, 2009
Anonymous
  • 655 Answers
SOURCE: how do i wire two kicker l7 dual 2 ohm subs to
Hello moore_broder,
Your MTX 7801 is stable at 1 ohm, but you cannot wire a pair of DVC 2 ohm subs to that impedance. They can only be wired to 1/2 ohm which is too low or to 2 ohms.
Series the voice coils and parallel the subs. On each sub, jumper Black to Red/White Dot, then run both red's (positive) and both black/white dot's (negative) to your amp terminals.
The diagram is here.
Hope this helps.
Posted on Sep 25, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: wireing two dual 4 ohm kicker cvr 15s on a memphis
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 29, 2009
I have 2 kicker cvr12 @ 4ohms each..how to wire these to my mono block (1 channel) at 2 ohms load
The CVR12 have dual voice coils, which will run at 2 or 4 ohms depending on your configuration. Here's a diagram to employ both sides and keep it at a 2 ohm load:
3helpful
What would be the right wiring on a cvr 12 to 4 ohms i am running a hifonics 2000 class D thanx for the help
Assuming that you have a 4 Ohm Dual Voice Coil (DVC) sub, you should wire it in parallel for more output. Solid red connects to red with white dot, and goes from solid red to amp positive (+). Solid black connects to black with white dot, and goes from white dot to amp negative (-). For a good diagram, go to this link: http://kicker.com/dvc_wiring
How to connect dual vouice coil to amp
Hey well your gonna need to give more info. is the sub dual 2ohm dual 4ohm. if you have a dual 2 ohm you wire one + to one- (like a jumper wire)and then your other +.- go to your amp as 4ohms, if you have a dual 4ohm model and your amp can handel 2ohm stereo then wire your +to+ to +on the amp and the same for your -. it will bring a 4ohms to 2 ohms by connecting pos. to pos. and neg.to neg. then to your amp.
2answers
I have an Audiobahn A8000T amp and 2 12" Kicker CVR (DVC) Dual voice Coil. The Subwoofers are 2OHM a peice. What is the best way to hook this all up to run a 2 OHM load to my subs?
This is a link to Kicker for your CVR12 Subs...if you have the 2 ohm version (2 ohms per voice coil) and you have 2 speakers ....you will need to wire EACH speakers voice coils in series to get 4 ohms from each speaker and then wire the 2 speakers in parallel.....as in....2 ohms in series with 2 ohms = 4 ohms....both speakers wired same way, then in Parallel with each other = 2 ohm load. Page 2 of this link gives examples of both series and parallel wiring of your speaker.
http://www.kicker.com/sites/default/files/2006CompVX.pdf
If you are still not sure as to my description of ' How To',
PLEASE respond and I will attempt to explain it EXACTLY via wiring directions.
How do i wire two kicker l7 dual 2 ohm subs to play on a mtx 7801 class d amplifier
Hello moore_broder,
Hope this helps.
1helpful
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
If my woofers at bridged and my and is too but it
first you dont bridge both ,, 2nd you will need to find out what ohms your speakers are , and if dual coil what ohms each coil is ,, then find out what ohms your amp runs at , at full power.. then try to match your subs to the same ohm load,, REMEMBER there are diff ways onto how to hook subs on which will change the ohms.. good example 1 dual coil sub each coil is 2 ohms then you can hit a 1 ohm or 4,, depending how you hook them up .. When adding more subs and how you hook them up changes the whole game.. if your not sure on how to hook them up read a manual or go to a local shop you can burn your subs up or worst the amp if hooked up incorrectly ..
Help wiring kicker cvr12's
Hello pr7met7me,
Assuming that the "old sony box" has 2 chambers with at least 1 cu/ft of internal volume each, there should be no problem running the Kickers. The CVR's are dual voice coils and come in either 2 ohm or 4 ohm versions. The coils are wired together either in parallel or in series and then wired to the box terminals.
You did not specify what make and model of amp that you intend to use. The amp will dictate how the sub voice coils are wired. You do not want to go below the minimum load that your amp is capable of supporting. If your subs are the 2 ohm version, you wire the dvc's in parallel and then parallel both subs to the amp, your final load to the amp will be 0.5 ohm and there are not many amps stable at that low of an impedance.
The terminals with the white dots are for the first voice coil. The terminals with solid-red and solid-black markings are for the 2nd voice coil. In a parallel setup, you would wire the white-dot positive and the solid-red terminals to the box internal positive and the white dot negative and solid-black to the box internal negative. In a series setup, you would run a jumper from the white dot negative to the solid-red and then connect the remaining terminals to the box terminals.
Hope this helps.
2answers
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Kicker Comp CVR 12 x 12 Car Subwoofer Logo
Top Kicker Car Audio & Video Experts
Morne Olivier
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Oloyede Monsuru
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
