On the front right where it says LIVINGSTATION, that panel lifts out. Inside you will see two screws, loosen them, (they will not come out because of a retainer) gently pull the box out. Once it is out, there is a wire retainer that has to be removed. Once that is removed, then loosen the nuts from the bulb. Then reassemble. Putting it back in, takes patience, do be in a hurry when putting it back in. It will only go in one way, make sure the bulb is facing the inside when sliding it back in. Hope this helps you..I haven't yet replaced the whole unit from epson ($300) only the bulb, which didn't need it after all. If you have any questions e mail me..
