Download to usb flash drive lg dv582h - Computers & Internet
Posted by eugene labschin on
Brian Sullivan
  • Computers & ... Master
  • 27,725 Answers
If your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
Windows 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
if you dont have a disk with the drivers
you will need to download one try one of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
hope this helps
Posted on Nov 17, 2012
How can we play video from a USB device? Why can we not download more apps???
Shop for tv How can we play vide... on Google
WD TV® Media Player
$109.99
Staples
(165) Hauppauge Computer Ha...
$84.99
Dell
(400) C2G 29351 Micro USB to...
$21.23
Sears Audio?Technica ATR2USB 3.5...
$13.95
zZounds Diamond ATI TV Wonder H...
$39.92
B&H Photo-Vi...
(12) Search Results
    USB Flash Drive Movies on your Flat Screen TV - YouTube
    ? 4:10
    https://www.youtube.com/watch?v=ge4Wo9FQf8w
    Oct 5, 2014 - Uploaded by 21NorthMedia
    How to watch Movies & Photos from your USB Flash Drive via the USB Port on your Flat Screen TV.
    Watch a movie on your TV from a USB drive. - YouTube
    ? 2:40
    https://www.youtube.com/watch?v=jOhvbdVkPaM
    Nov 10, 2012 - Uploaded by DIYallday
    I'm trying to play movies from my USB port, but when I plug it I can't .... My LG 47" TV will recognize and open the flash drive, but shows empty.
Jan 05, 2016 | Televison & Video
Tip
LG DV582H region free code
Here are the steps to make your LG DV582H DVD region free.
1) Power on (with no disc)
2) Wait for msg "No disc"
3) Open tray
4) Push three times number 0 (i.e.: 0 0 0)
5) A blue screen appears with the code region factory set, and the option to set the new region code
6) Press 0 (zero)
7) Press Pause (A msg say that you have to press de new code and them press pause to confirm....so, is to easy)
8) Close tray
9) Turn off
Works 100% for my LG DV582H region 4, now its region free!!
Good Luck
on Jan 03, 2011 | Audio Players & Recorders
Disk error on my new LG DV582H DVD Player
Disc error can mean laser pickup assembly issues, this is clearly a manufacture defect and needs to be returned, any tampering will void the warranty.
Aug 13, 2012 | Televison & Video
Lg 670 stuck
I had the same problem with my LG bd670 blu ray. I fixed it. It was a failed firmware update. I went to the LG website and downloaded the update and copied it onto a flash drive. I unplugged my blu ray (hdmi cable too), put the flash drive into the usb port on front, and plugged in the power cord. It took a couple of minutes but it loaded the update from the flash drive and shut off. I plugged the in hdmi cable and turned on the blu ray and done. All was well in the world again. I hope this helps anyone with the "boot" error message on the LG bd670 blu ray player.
Mar 23, 2012 | LG BD670 Bluray 3D Player
The usb socket on a LG Intelcore duo computer does not accept usb flash drive. The socket seems to be of the same size as the head of the flash drive. What is the solution for that?
Your usb port must be disconnected or damaged contact our systm administrator or your system manufacturer or try another usb stick.
Feb 14, 2011 | LG NB E500-JAP51A Notebook
Need a multiregion unlock code for LG DV582H?
3) Open trail
6) Press 0 (zero)
8) Close trail
9) Turn off
Good Luck
Nov 29, 2010 | LGDVB418 DVD Player
I have an 47LG LH30 LCD television, when watching shows that are broadcasted in HDTV, there is a delay between the sound and picture. How do I fix this problem?
You need to update to the latest firmware. This was an inherent problem in many LG LCD TVs released around the same time as yours but can be easily resolved by installing the latest firmware. You can call LG to have them send it to you on a USB flash drive or you can go to their website and download it along with the instructions. You will need a USB flash drive an plug it into your TV to intstall the firmware.
Nov 09, 2009 | LG 42LC2D 42 in. LCD HDTV
My Lg 1G USB Flash drive will not show content
go to run
Change To ur pendrive directory
type
format/q
click enter
It will work. thanks.....
Aug 02, 2009 | LG Computers & Internet
My lg flash
usb drive?
do you see it in the device manager?
Apr 27, 2008 | Electronics - Others
Computers & Internet Logo
85 people viewed this question
Ekse
Marvin
Marvin
