SOURCE: Need to reset all the
The problem may be that the carrier is binding on return, put some light lube (WD40 works well) on the silver shaft that the carrier slides on.
DicktO
SOURCE: How do you save margins and save information to
First thing is to be sure the batteries are good and the holder is clean. If there not you will get lo batt on the display and everything you put in will clear when you turn it off.
To save something Press store and an address 01-99 type info when done press store again info. is stored. to print press play and the address. To delete use del and the address.
DickyO
SOURCE: How do I re-set the
Go to the R. margin, press and release mar rel key, space to desired location press R. mar key.
DickyO
SOURCE: The left margin is stuck
Put a shot of WD40 on both sides of the silver shaft that the carroer
slides on. If that doesn't do it put some on the carier motor bearings.
The front one can be reached from inside of the T/W the rear one yuo
will have to remove the case of fish the straw thru it. The motor is
located on the R. rear corner.
DickyO
SOURCE: Lexmark/IBM Wheelwriter 1000 Typewriter has
First try a little shot of WD40 on both sides of the silver shaft that the carrier slides on. If that doesn't do it you will have to get some on the carrier motor bearings located in the R. rear corner under the case.
DickyO
Testimonial: "This worked! No issues any more! Thanks :0)"
