Kenwood KAC-9103D Car Audio Amplifier Logo
Question about Kenwood KAC-9103D Car Audio Amplifier
I have 3 JL Audio 12
How can I adjust the Bass Boost,Frequency(Hz),Sensitivity to make it sound nice n clear...When I put music to a certain volume,the bass sounds to hard n it rattles to much,I will like for it to sound more clear n less rattle..
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
tip
What is the purpose of a graphic equalizer?
A graphic equalizer is designed to allow the user to tailor the music to his or her personal hearing. Obviously not everyone hears frequencies the same. As you get older or are exposed to loud noises you lose sensitivity to certain frequencies. To compensate for that you can boost or cut the fequencies being played through your system. Originally the graphic equalizer was designed to make corrections to bad recordings and deficiencies in the recording medium of the time. Now they are used more to compensate for hearing deficiencies. To understand how an equalizer works you need to understand that ideally the normal person can hear about 20 khz of audio when they are young and have perfect hearing. Probably more realistically they can hear 20 hz to 15 khz. Enter the equalizer. All sounds are heard differently according to the intensity of the frequency. If your hearing is bad, say down 10db at 10khz, with an equalizer you could boost 10khz by 10db and make up for it. An equalizer contains filters which breaks the audio spectrum into bands. Could be 3, 6, 10, 15, 20 or more. The more bands the more the equalizer costs but the more corrective power you have. We have equalizers with 64 bands. . The numbers on the sliders are the frequencies your equalizer can boost or cut. Keep in mind that they are the center frequency and will effect frequencies on either side for about a 10db range. So you can cut/boost frequencies at 50hz (very low), 200hz (low but still bass), 800hz (low to mid range), 3.2khz (range of speech), and 12.8khz (high frequency). The best way to observe how your equalizer works would be to play something and adjust one control at a time to see what it does. You will notice a difference. Then it basically becomes a project to adjust the unit to the way that you like to hear your music. You like bass, boost the low frequencies. Like the highs, boost them. Give it a try.
hardrocko
Thanks for using FixYa
1helpful
Does the alpine 9845rb have a clock display?
yes it does see below
  • CD receiver with built-in amplifier (16 watts RMS/45 peak x 4 channels)
  • detachable face with Quick Search button
  • plays audio CDs, CD-Rs, and CD-RWs including discs burned with MP3 and WMA files
  • Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
  • BBE sound processing
  • two sets of preamp outputs
  • rear-panel minijack auxiliary input
  • clock
  • CEA-2006 compliant
  • CD frequency response 5-20,000 Hz
  • CD signal-to-noise ratio 105 dB
  • FM sensitivity 9.3 dBf
  • warranty: 1 year
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • 2helpful
    Audio settings for pioneer DEH-P3100UB
    The q1w and all that- is a way to fine tune your eq settings: the q means "frequency" the w means wide and the n means narrow. if you choose to boost your lows at 125 hz which is a low midbass the q selection you choose will focus more on the frequencies very close(narow) to that frequency. if you choose a w setting it will spread the boost to frequencies further away(wider) from the center frequency(125hz) Dink around with it and you will notice the way it contours the sound a little. The different numbers associated with the lows mids or highs are the frequencies that you want to boost when you're adjusting your sound-example if you turn up the bass and it starts distorting your speakers = go into settings 2 and change the "lows" Q to a higher frequency(change 80 hz to 125hz) and that way it wont muddy up your sound quite as bad if at all
    No manual for my amp.
    • Class-D Monoblock Amplifier
    • Bass Boost Level and Frequency Remote Included
    • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
    • Variable Input Sensitivity: 200mV - 5V
    • Phase Shift: 0° / 180°
    • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
    • High- and Low-Level Inputs
    • 1 Ohm Stable
    • RMS Power Output:
      • 500 watts x 1 chan. @ 4 ohms
      • 900 watts x 1 chan. @ 2 ohm
    • Preamp Outputs: 1 Pair
    • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
    • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
    2helpful
    JL 13w7 & 1000/1 Settings
    There is no "perfect" setting that can be placed in a manual. It's all done by ear. Your settings will vary depending on the vehicle you are in, the type of enclosure you have, the type of music you listen too, how much voltage your deck put's out. There are many variables, but I can try to give you a basic guide.
    First of all you need to know your enclosure. If you have a ported enclosure tuned in the mid to low 30's you may want to set the low pass to around 70-80 hz with your sub sonic set at 30 hz. this will give you the higher bass frequency you need for the loud bass you want, and protect the sub from going too far below the tuned frequency of the enclosure, and losing it's composure.
    As far as the gain, and bass boost are concerned, you just have to adjust them by ear. First adjust the radio volume to normal listening levels, by that I mean as loud as it can go without the speakers in the car sounding like ****. Now you adjust the gain first. slow turn the gain control, carefuly watching and listening to the sub.. Adjust the gain to the point of the woofer getting a lil sloppy then back it down a bit until the sound is clean again. Now do the same with the bass boost. if there is a bass boost frequency adjustment, set that as close to the tuned frequency of the box as you can.
    If you are in a sealed box the adjustments are a bit easier, and are all about taste. Adjust the radio as described before, and put on your favorite song. Next start udjust thing lowpass frequency to taste, not too high tho, try not us higher than 100 hz in your sub's for better sound. Sub sonic is not quite as important in a sealed box, as there is much less danger of the sub losing control.
    Well good luck, and hope this helps!
    2answers
    I have the Sony XS-L120B5D subwoofer with enclosure: sensitivity-89db RMS-600 watts Peak-2000 watts impedance-4 ohm frequency rangh-20hz-2000hz its hooked up to an Arc Audio ks 300.2 amp: class-g/h power...
    Do you have the crossover switched to "low pass"? and the frequency control below 80hz? Do you have the manual? If you need more help, post a comment and I can walk you thru it. Hope this helps
    1helpful
    3answers
    Adjusting wattage on kenwood kac 9103 class D mono amp
    That amplifier is 900W x 1 @ 2ohms.
    If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
    Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
    Car audio
    Product Details and Features PLX-520
    Key Features
    Amplifier Type grayquestion.gif Dual Channel Bridgable grayquestion.gif Bridgable RMS Power at 2 Ohms 400 W x 2
    Performance
    Frequency Response 10 Hz - 50000 Hz Signal to Noise Ratio grayquestion.gif 102 dB THD at Rated RMS Power 0.01 %
    Crossover / Equalizer
    Bass Boost grayquestion.gif With Bass Boost Low - Pass Frequency 50 Hz - 120 Hz High - Pass Frequency 80 Hz - 800 Hz
    Other Features
    MOSFET Circuitry Yes 3 Way Ready Yes
    Dimensions
    Width 10.4 in. Depth 17.7 in. Height 2 in. ..This is what I found for logic soundlab PLX-520 Amplifier, hope its what you were looking for. Don't forget to rate answers.
    Open Questions:
    See all Kenwood KAC-9103D Car Audio Amplifier Questions
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
