Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston urdriver installer - Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Posted by usonkenterl on
Brian Sullivan
  • Kingston Master
  • 27,725 Answers
If your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
Windows 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
if you need more help with this post a reply
if you dont have a disk with the drivers
you will need to download one try one of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
hope this helps
Posted on Nov 17, 2012
2 Related Answers
riyan noveanto
  • 121 Answers
SOURCE: i need urDrive Software for
u can get i from this site:
- rapidshare.com:
http://www.rapidshare.com/files/410018837/KINGSTON_urDrive.7z
- megaupload.com:
http://www.megaupload.com/?d=274DMGJE
from kingston.com there is two choice based on product:
-DT101G2 : http://www.kingston.com/support/USBFLASHDRIVES/downloads/default.asp?s=DT101G2
-DT102 : http://www.kingston.com/support/USBFLASHDRIVES/downloads/default.asp?s=DT102
hope this useful. regards, riyan.
Posted on Aug 08, 2011
DHINCE10
Dino Dichoso
  • 169 Answers
SOURCE: my kingston dt101 g2 is
To download the application that you need please refer to the link provided below.
Please click HERE to download the file.
Posted on Jul 07, 2011
I had deleted the "Urdrive " folder in my 4GB USB.
the best way to get back deleted files is to use a file recovery software, recommended asoftech data recovery as it helped me before. you may refer to this tutorial
Recover files from USB drive
Oct 11, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do I rename a URdrive usb drive
just right click on your drive select rename
hope it helps
Oct 07, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I need urDrive Software for flash kingston?
- rapidshare.com:
- megaupload.com:
Aug 08, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do I rename the Urdrive when it shows up on My Computer?
Something to add to HoboPelican's solution, if you open the autorun.inf file with notepad or wordpad you can change the name on the last line where it says "LABEL = KINGSTON URDRIVE" then just replace KINGSTON URDRIVE with the name you would like to call the drive.
Jun 12, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I am unable to install my urdrive datatraveler 101. when plugged into my computer it says driver was not successfully installed contact manufacturer of hardware
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Apr 22, 2011 | Kingston Computers & Internet
I have uninstall the URDRIVE software and deleted it from my thumbdrive. But now, i want install it back into my thumbdrive and i don't know how and where to get the urdrive software.
If you format your drive you will lose the urDrive software.
Get another copy here: http://www.kingston.com/support/urdrive/urDrive_1.1.(124)_GA.zip
Installation Instructions:
Once WinZip opens (or an alternate compression tool), highlight all of the urDrive files and extract them directly to the Kingston drive.
Oct 06, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I want to download urdrive of kingston
urDrive CAN be downloaded from the official Kingston website. They provide it because often people who have their USB drive lose the software when they format the drive. However, depending on the version and where you are trying to install it, you may see this error: "This drive is not authorized to run this software."
Sep 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
110 people viewed this question
Top Kingston Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Mike
Harish  Ramaiah
Harish Ramaiah
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
