Question about Brother DCP-J140W Compact Inkjet All-In-One
Unable 50 of dcp j140w borther printer
How can solve this error 50 problem ? Give me you are answer. Thank you so much
Posted by pyoedu on
  • 2 more comments
  • Mishra Pande
    Mishra Pande Apr 26, 2016
    1. Press the Set/OK button, then Menu, then Mono Start followed by the up arrow key four times. These buttons have to be pressed independently and should be done in rapid succession. If you have done this stage right you should be presented with the word ‘maintenance’.
    2. Using the Up/Down arrow keys select the number 8 and then press Set/OK. Then select the number 0 and then press Set/OK.
    3. At this point we need to get in to the Purge option which, depending on the machine will either be a case of pressing Mono Start repeatedly or using the Up/Down arrow. We recommend trying one method and if it isn’t right for your machine turn the printer off and back on again, start the process from the beginning then try the second method.
    4. Once PURGE is on the screen (usually the word purge will be followed by a reading indicating how much ink has been deposited) use the up/down arrows and the set/ok key again to enter the numbers 2, 7, 8 and then 3 on the screen.
    5. The number after PURGE should now reset to zero. Press the Stop/Exit key to go back to the main maintenance mode menu.
    6. Using the up/down and SET/OK keys enter 9 and then 9 again to exit maintenance mode.
  • vishal
    vishal May 10, 2017
    not working
  • Anonymous Aug 15, 2017
    I was pretty excited to see that it said maintenance 99 in the end and then refreshed itself, but it just went back to the error message "clean unable 50". is there anything else I can try?
  • Mateusz Sak
    Mateusz Sak Dec 05, 2017
    After several unsuccessful attempts, I turned my printer face up and turned it on while holding it in this position. And what? it started to work
    Maybe because the ink was easier to flow into the printer.
Clive
    Habit-Forming:
    New Friend:
  • 97 Answers
Hi, This link may be useful
https://www.youtube.com/watch?v=SbHNQKB_oDk
Posted on Apr 26, 2016
5 Related Answers
Anonymous
  • 787 Answers
SOURCE: my printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Posted on Nov 03, 2009
Anonymous
SOURCE: Init unable 50 appears on
clean unable 46
Posted on Jan 07, 2011
zaldy_gloria
SOURCE: Error: init unable 50
init unable 50 how to resolve this problem..?
Posted on Jun 28, 2011
Anonymous
SOURCE: Brother DCP 110C printer error
thats what I find useing the search button here:
http://www.fixya.com/support/t265668-not_printing
Posted on Feb 20, 2008
Nikolay Boychev
  • 525 Answers
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Jan 23, 2011
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Unable to print 50 error message
Thank you for visiting Fixya!
MFC-440cn
Error Message 50
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees
2) make a note of where each connector goes
3) release the Ribbon and 3 Multicore cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees.
4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.
5) Remove front panel by disconnecting ribbon and wireing on both sides.
6) Remove 6 Screws (2 on back, three at front and one middle right
7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.
8) Re-Seat Encoder Strip into guide. (The Transparent strip)
9) Re-assemble in reverse and Hey Presto.
A handy trick:
Put a 1,5inch tape onto the printhead cover where the encoder strip runs thru to prevent this error in future.
(Please give me a big thumbs up when you rate my answer, thanks.)
Jan 28, 2010 | Brother MultiFunction Center MFC-440CN...
Unable to Print 50, not fixed
The 50 series errors have to do with the cleaning station on the right, any paper or foreign matter will stop them from functioning, also a mickey mouse spring loaded gear that likes to stick and give you that error.
Aug 06, 2009 | Brother MultiFunction Center MFC-440CN...
The display shows
This stands for Error number 50. I need to know what camera this is to give a definitive answer
Jul 19, 2009 | Sakar 23070 Digital Camera
Pannasonic Toughbook CF-47 with Windows 2000, get error message: "operating system not found." Tried all 3 drives, rebooting and charged battery fully to no avail??? Please advise. Thank you.
This means that the computer cannot find an operating system on the hard drive. This is often because the hard drive has gone bad. Replace with a new drive and reinstall windows and that will solve your problem. Thanks and please if you could remember to give this answer a rating of fixya; even if the answer isn't the greatest news :c) Thanks! :c)
Feb 18, 2009 | Panasonic Toughbook CF-27 Notebook
Error code f1 e2
Hi Krazytech,
Happy to help you!
But I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Aug 24, 2008 | Kitchen Ranges
F7 f20 error
Hi BBlackie,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model #
and download the manual.
1-800-905-9505
They answer 24/7
Thank you Neil
Jul 25, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Fridgedaire range f7 22 error
Hi Van,
Happy to help you!
1-800-905-9505
They answer 24/7
Thank you Neil
Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Jul 16, 2008 | Frigidaire PLEF398AC Electric Kitchen...
I have a brother LC-51. I am getting a message that says unable to print 50. I have no idea what this means. Thank you Jay Herzog [email protected]
and you should get an error 30 which toggles to error 50, i guess.
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
btw: could you plz name modell type next time? Its easier to give hand, though.
Apr 28, 2008 | Office Equipment & Supplies
Brother DCP-J140W Compact Inkjet All-In-One Logo
6,266 people viewed this question
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
