Washer is making different noises during wash and rinse cycle
Making different noises, during wash cycle it makes a low pitch moaning noise. during the spin cycle it sounds like a whining noise with different pitches. tonight it made a load click noise and stopped as if the motor experienced a over temp and tripped out. after a few minutes I was able to restart the washer.
Posted by Lex Luther on
Richard Roth
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 16, 2012
5 Related Answers
Anonymous
  • 55 Answers
SOURCE: LG makes a high pitched sound during water add cycle
Hello.
The high pitched sound is a definite sign that the water valve in use is failing. The squeal is from a restricted water flow through the valve because it is not opening all the way. You will need to choose cold or hot to narrow down which valve is bad and replace that one.
Posted on Jul 16, 2009
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Posted on Sep 07, 2007
Anonymous
SOURCE: Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Posted on Sep 14, 2008
Anonymous
  • 373 Answers
SOURCE: Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Posted on Dec 11, 2008
Paulo
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
could have been the motor,you might also smell like a shellac kind of smell,when the motor overheats,also how old is it and what's the brand name and model number.you can feel the motor,if it's hot then it is cutting out for some reason.
Dec 20, 2017 | Washing Machines
Maytag MVAT346AWW
Remove the back lower left access panel. You will find the drain pump there. 95% of these problems that you have described is from the drain pump bearing going out. If possible, run the washer with this panel opened and listen to the pump. If the noise you hear is coming from there replace the pump with the new designed pump. Here is the pump to order. To replace the pump, tilt the washer back and remove the belt, then remove the two hoses from the pump and then the three screws that hold the pump on. If the pump is not the problem, post back to me.
Nov 16, 2012 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Washer making noise during spinning cycle.
why is my ge front load washer making a rumbling noise
Jan 06, 2009 | GE Washing Machines
Kenmore elite washer 26922
Sep 07, 2007 | Washing Machines
Washing Machines Logo
806 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
