SOURCE: oil drain plug 2004 harley dyna wide glide
your oil drain is on the right side pipe side of your bike look under near the rear back part of your frame you will see a plug with a one quarter allen key threaded plug style bolt kinda hidden in bridge plate of frame it is flat in conjuction with line on bike it is in area right behind where your back pipe expands to baffle of pipe where its skinny and then gets bigger its the one closest to you
SOURCE: will a gas tank off a 5 harley dyna wide glide
It sure will!! You answered your own question. guess i get no points for this one.
SOURCE: 03 HD dyna wide glide blows oil from breather...
How many miles do you have? You probably need to have your oil pump alligned. They get out of wack and cause over oiling. I believe it caused by not being able to return oil efficiently. An evo tappet block alignment tool is now used to align the TC internal oil pump.
SOURCE: 2010 harley dyna wide glide. when I press the
Is the clutch cable adjusted correctly, you may need to adjust the cable so that the clutch is released more fully, there will be an adjuster on either end of the clutch cable - adjust it so that the cable is tighter - but there should be a little bit of play left in the clutch -
if this does not cure the problem you could have some gearbox damage,
The bike is still under warranty so take it to a harley dealers and have them look at it.
SOURCE: capacity of primary oil on a 01 dyna wideglide
Three quarts. Check the oil level with the bike on the side stand. The dipstick has two marks on it. The top mark is "Full Hot" and the lower mark is "Full Cold". Maintain the oil level between the two lines. Do not overfill.
