SOURCE: 32inch Akai tv
contact your friend and ask for the code! if not, look in the manual and try to fix it. =]
SOURCE: Sound no picture brand new tv
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
SOURCE: Akai 32" flat pannel making a humming sound?
replace the a/v RCA cables to start with and then if you still have a problem, you have loose connecitions on the a/v board
good luck
[email protected]
SOURCE: no signal
Make sure the tuning band is set to cable not air.
Connect a known good video signal ie: dvd player or game console, check to see if that works.
Let me know how it goes.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
