Router has worked fine for years no problems. Suddenly yesterday it turned itself off. I unpluged and plugged back in. It runs through start up and then immediately powers down. Have tried to reset several times.
SOURCE: Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
WRT54GX2
SOURCE: router WRT54G no Power led on
HAVE YOU PRESSED THE RESET BUTTON ON REAR OF ROUTER (LEFT SIDE).IF NOT TRY THAT OR FOR MORE INFO CONTACT TECH SUPPORT AThttp://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1149562300349&pagename=Linksys%2FCommon%2FVisitorWrapperRICHARDM69
SOURCE: Blinking power light - router not working properly
Blinking power light on the Linksys routers indicate 2 things. 1st is firmware problem, 2nd is the worst one which is defective router. You can still revive it if you can reload the firmware. If not, it's a dead one and you need to purchase a new one. And man, your router is a very old one. You must switch to wireless G router, its 5 times faster than your wireless B and it only cost 30 or 40 bucks
SOURCE: last night something happened to my WRT300N
Check your power adapter with a voltage meter to verify it is producing the correct voltage.
