I have just replaced the fuser unit and transfer belt on my Samsung CLP-325. Although i have replaced these items, i am still getting the replace fuser and transfer belt warning. How do i reset the counters to zero, with out installing a chip? I know on the CLX 3175 you can go into tech mode on the printer to reset the counters. Does the CLP 325 have a tech mode? Any help would be muchly appreciated.
SOURCE: Samsung CLP 500 series printer problem
If you have the manual for the printer look up how to reset it.
also try unplug and push in the power button, then plug it back in and turn it on. let me know if that works.
SOURCE: Replacement fuser unit for Samsung CLP-510
probably your best bet is direct from samsung. go to their website, samsung.com and click on contact..give thema ring and simple ask..if they dont have one, they can direct you to the closest place that would have one or places you can order online.
SOURCE: Samsung CLP-300N was asking to replace transfer
open the top cover press and hold the main button wait for the 3 lights to go up, release and cover
SOURCE: Samsung CLP 510
Some toner may have
spilled in the printer. If so, you will need to clean it out. Also, the toner cartridge may be defective and letting too much toner out at
one time, the solution is to replace
the toner cartridge.
Take care.
SOURCE: samsung clp 315 printer shows "replace/install
Hi there your printer wast toner drum is full. So just remove that and make empty the drum & then refill the toner box. now use. Thanks.
