Netbook has already got 1 gb installed ,i wish to install another 2 gb module
SOURCE: Install 2 RAM modules of 1 GB
The other memory slot is underneath the keyboard. To remove the keyboard, you will have to remove 2 screws from inside the memory expansion area, underneath it's cover. Details can be found on HP's website (http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00777623/c00777623.pdf)
-Backu
SOURCE: trying to upgrade memory from 1 gb using 2x512 mb
check your ram slot is working or not and second it is that your ram speed should be same otherwise the both ram will not work.
SOURCE: trouble w/ removing memory module slot cover
omg!!! are you kidding me? HOW SILLY!! Anyway, don't worry about breaking anything.. You won't. #1 Make sure to remove the screw completely before trying to remove the plate. there should be a raised area or **** where you can slide a flatheaded screwdriver in to pull it up.. Try that and dont worry, k? JUST BE SURE TO UNPLUG AND TAKE THE BATTERY OUT BEFORE YOU DO ANY MAINTANENCE, OK? GREAT LUCK!! LUCKY4LYNN2 ps. PLEASE RATE ME, K?
Testimonial: "helpful and positive. Thanks"
SOURCE: i just installed windows 7 ultimate os on my
If you have just installed the 2gb memory, it may be faulty, it does say that you can use 2gb modules so you may need to swap it
SOURCE: Replace 1 GB memory with
You should only need to unscrew one. http://support.gateway.com/s/notebook/2009/gateway/lt/lt20/LT20faq5.shtml
