I have a Kohler Residential 11RMY generator, powered by natural gas. The main natural gas line to my house was shut off to have some work done. When the gas was turned back on, the plumber turner on all of my gas appliances to bleed the lines of any air and make sure they all worked again. But we forgot about the generator. Now it does not strat and I think that maybe I somehow need to bleed the gas line to purge any air? I looked at my operations manual, but it doesn't tell me anything. The generator turns over just fine, but it doesn't seem to start. Or if it is starting, it shuts down in seconds.
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
SOURCE: Kohler 11rmy-q53 generator.
The first thing I would do is to clean and dry air filter. If it is a foam material you can use a warm water and a few drops of dish soap.Rinse thoroughly and let dry. I also would try a small amount of octane booster in my gas. Hope this helps you.
SOURCE: Just finished installing a 20 KW Generac generator
Check the connections on the tranfer relay and two coils. The two coils have blue wires. I have seen them come off from assembly or shipping its common. Each coil has two blue wires #8 and E1 with crimp steak ons and limit switches make sure there all pushed on all the way. Hope this helps
SOURCE: Coleman Powermate PM0545007 generator.
The generator has a low oil level sensor. Fill the oil all the way to the FULL mark and try it again.
IF you still have the problem after adding oil; repsond here and I can still help you. Just want to get this off as it has been 4 hours since your post.
Kelly
SOURCE: Kohler 12res installed 06/06, replaced
SCFO is either what is displayed just before it cranks or when it is first powered up. Sounds like the controller may have forgotten what engine its running or is getting a bad run signal from the start switch. In either case a 1 year old controller should not be doing this. I would try having a local dealer doing a firmware update as there were quite a few for this controller and if this doesn't fix the problem I would start talking warranty with whoever replaced the controller.
