Question about GE 20.3 cu. ft. Bottom Freezer Refrigerator - Refrigerators
Fill ice maker with tap water and allow the water to
freeze. If when the ice maker cycles and drops ice into ice bin it chooses not
to refill with water at end of the cycle. That would point to the dual water
control valve. If ice maker does nothing when filled with tap water that will
indicate a defective ice maker. The model number you listed does not appear to
be correct. Look around the fresh food section door frame and see what you
have. This could be the ice maker or the dual water control valve causing this
problem. Thanks Sea Breeze
Posted on Nov 16, 2012
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
SOURCE: THe ice maker has stopped working in my GE refrigerator.
change icemaker
Posted on Apr 06, 2009
SOURCE: ge monogram zd115c automatic icemaker not making ice
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
Posted on Jul 29, 2008
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
Sep 09, 2017 | GE Refrigerators
Aug 14, 2014 | Refrigerators
Jan 11, 2013 | Refrigerators
Sep 29, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
201 people viewed this question
