Question about Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX)
How to config wireless camera to netopia router
5 Related Answers
Dave Byrne
  • 58 Answers
SOURCE: How can i unlock netopia 2247NWG
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Posted on May 10, 2008
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Programming Netopia 3347 wireless router
You mean what program? Telnet. Here's the quick setup. If it's already been installed and password protected, you'll need to grab the installation guide somewhere else.
http://www.netopia.com/support/hardware/manuals/3347W-ENT_qsg.pdf
Carl
Posted on Aug 29, 2008
spincycleus
Douglas Erikson
  • 62 Answers
SOURCE: WHAT ARE THE STEPS TO
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Posted on May 01, 2009
Ullekh Tandon
  • 169 Answers
SOURCE: need help config netopia wireless router to
hi
first of all try to connect the router to the computer and then do
ipconfig on run box
once you do this it will give you a black screen of command promt note down the default gateway
now after doing this open up your browser in the computer and then try to type http://defaulgatewaynumber and then hit enter
once you do this you will be able to get into the gui page of the router and then from their you can configure the router on network
if you get some problem in doing so please get back to me on fixya
thanks
techbuddies
Posted on Oct 25, 2009
Jael Saavedra
  • 62 Answers
SOURCE: HOW do i connect two xbox 360's to xbox live using
select the wireless network name for your router thats all ;)
Posted on Apr 27, 2010
Netopia 7000 router
try this website out they have just about every router out there listed Port forwarding the Netopia 2247NWG VGx router
Mar 14, 2014 | Netopia Computers & Internet
Conect webcams on a local network to a website
I presume that you mean "from a web site" that the web site is hosted somewhere out on the greater internet.... The problem that you are encountering is probably related to NAT (Network address translation). The "In" side of a router, is typically a "private network" there are pre-assigned number groups for these - a common one is in the 192.168.x.x range. Problem is that the "outside" of your Netopia router will be dependent on your ISP< and unless you are paying them extra for a static IP address, is likely to change every time you reboot - or sometimes they bump them every 24 hours. So, first thing is get a dynamic DNS Entry - www.dyndns.org is one supplier - I think you can get one address for free from them, pay for more.. YOu set up something like CMVideo.dynsdns.org on their site, and set up dyndns support in the netopia router... Then you want to open the specific port on your router, to go to the internal IP Address of your camera. (YOu mention Multiple Cameras - depends on the Camera you may have to go for multiple dyndns (one for each...) ).
I am a little confused/concerned about the second router "tier" - if you have the Belkin configure as an Access Point only, all good, if you are trying to run it as a router behind a router, it will probably never work - double nat-ting" is a no no with most consumer Routers. Simple solution is to tap from Netopia lan side to Belkin Lan side (rather than Belkin Wan Side)
Nov 14, 2013 | Netopia Computers & Internet
Tried 192.168.1.1 to get in also tried 192.168.1.254 cant gain access to the router to adjust some configs
You do need to find the IP....
Using a Windows Computer.... Get to a C: Prompt...
"Start", "Run" ...in white space.... enter "cmd"
At the C: prompt..... Type "arp -a" and hit the enter key.
Above command will show all IP's on your network.
Nov 05, 2010 | Netopia (3347NWG-VGX) Wireless Router...
How do i turn off the wireless on my netopia 2247nwg router
Type 192.168.1.254 Enter your password default Username-Admin Pass-Admin
Once in there find your wireless setting and turn it off. I personally do not have a netopia router but these are the usual steps, if you have any problems comment back and i will be glad to help.
Mar 20, 2010 | Netopia 2247NWG-VGx Wireless Router...
Need help config netopia wireless router to network
hi
ipconfig on run box
thanks
techbuddies
Oct 24, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Can't Access Netopia Admin Panel Via IE
Try this and see if it works for you. Telnet into the modem. Hyperterminal will work fine for this.
Type config, then hit the enter key.
Type set, then hit the enter key.
At this point look at your monitor. Does the bottom line look like this?:
autoConfig (on) [ off | on ]:
If so, type off. Then hold the enter key down for several seconds untill you get to lines that look like this:
Netopia-3000/xxxxxxxx (top)>>
Then type save and hit the enter key.
When the screen says that the configuration data has been saved, type exit and hit the enter key. Then type restart and hit the enter key. When the modem restarts close hyperterminal and access the Netopia using your web browser.
Apr 12, 2009 | Netopia Cayman 3347W-Ent Wireless Router
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
spin
Jan 11, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Carl
Aug 29, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
No wireless
first make sure wireless enabled and find out what channel the item your trying to connect to is the same as the router and set both accordingly. I had same problems with security cameras i turned security settings off for wireless and switched everything to channel 6 on router and cam and wet with 806 and works fine had to restart router not reset.
Aug 07, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia 2247 NWG can't find Atheros AR5007EG WLAN
ok heres the solution.
goto start,control panel,performance and maintainance,administrative tools,services.
Scroll down to bottom to WIRELESS ZERO CONFIG,double click and click start.
now exit and wait a minute and your limited or no connectivity should change to connected,
let me know if this helps,
Patrick.
Aug 02, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX) Logo
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
