Question about Sony PS3 PlayStation 3 Game Console 40gb
Playsation 3 40gb power light is not green, its red instead. Its also got an extremely loud fan.
My Sony PlayStation 3 40GB will only display a red power light. The power light is suppose to be green but mine is not, its only red. My ps3 is also experiencing a very loud fan. From the time I start to play a game until i turn the console off the fan is extremely loud. Ive also noticed that the back of the ps3 is very hot as well.
Posted by David Halcomb on
  • David Halcomb Nov 20, 2012
    I appoligize for not responding sooner. I wanted to give an update on my ps3. I completely disassembled my ps3 and used a can of air duster to completely clean out the dust. I then removed the all of the old thermal paste and applied NEW (Antec Formula 6 Nano Diamond Thermal Compound). Ive applied this past on my Intel Core i3 processor and its worked fantastic, but unfortunetly my ps3 is still overheating and causing the fan to kick into high speed.
    I also want to mention that the light is green and blue when the ps3 is turn on which is good, however when i turn the playstation 3 off the red light is not turning on like it should. Has anybody heard of this problem before?
Marc
    Novelist:
    Scholar:
  • 68 Answers
PS3 power light not green, blinking red light problem are common issues that you can try to fix it by yourself. Take a look to the following website to get the answer : PS3 Red Light Fix
Posted on Jan 02, 2016
bonzbonansya
    New Friend:
YLOD,,difficult problem,u try open youtubre how repair for YLOD problem>>
Posted on Dec 13, 2012
4 Related Answers
Anonymous
SOURCE: when i turn on my
Does the PS3 still work while the fan is running. This is typical with PS3, especially if the fan is dirty. It comes on and off to cool down the processors.
Posted on May 17, 2009
Anonymous
  • 105 Answers
SOURCE: having problem with my ps3
Sounds like the PS3 is bricked. Try using the recovery menu, Directions here: http://www.xtremeps3.com/2009/01/28/how-do-i-access-the-playstation-3-recovery-menu/
Posted on Aug 03, 2009
upbeatjunk
Tim Levesque
  • 231 Answers
SOURCE: What's wrong with the ps3 when you turn it on it
Sounds like an overheating issue to me. Make sure to keep it in a well ventilated area. Also, the next time you turn it on, put your hand near the vents to see if any hot air is being expelled through them. If there is NO air being expelled, you have a bad fan. It may also be that the heatsinks aren't conducting enough heat from the processors...this could be due to bad thermal paste. You may need to send it in for repair for this you can call 1800mysony.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Posted on Jul 03, 2011
franza1
franza1
SOURCE: My ps3 turned off during game play and the light
I'm afraid you have gotten the Yellow Light of Death ( YLOD ) you will need to have your PS3 repaired by a technician or you can Google YLOD and you will find a repair guide.
Posted on May 03, 2012
Ps3 40gb fan test fail
you over heated it thats a temp fix it wont work again
Jan 25, 2012 | Video Game Consoles & Games
My PS3 wont connet to the power, it turns on for a few seconds, and then it will disconnect from them power and turn off
Sounds like the Red light of death. Which is a problem with the graphics card. It can be fixed but don't take it to a 2bit computer repair shop that say they'll fix it for £60. The equipment needed for the repair costs thousands, (Infra red heat technology). Chances are they won't have one. Which model do you have, It was a very common problem with the original 60gb ps3's, also the 40gb with the loud fan noise are prone to the red light of death. Sony offer a refurb model for around £130. Hope this helps.
LJ
Mar 09, 2011 | Sony Playstation 3 (PS3) Console
Playstation is on but screen is black
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 30, 2010 | Sony PlayStation 3 40GB System
My ps3 screen wont show when i turn the ps3 on.
Jun 28, 2010 | Sony PlayStation 3 40GB System
Playstation 3 power supply switch off red light blinking on
its not the power supply. your cpu needs to be reflowed
May 31, 2010 | Sony PlayStation 3 40GB System
Loud revving then red light flashes after i turnon the main power
The system senses an over temp error, that's why the fan ramps up quickly. More than likely, you will need to have your motherboard reflowed by a service tech or Sony. That's about all you can do unless you know how to open the console and perform a reflow yourself. Hope this helps.
Nov 09, 2009 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on,red light goes green then red right away
Try disconnecting your PS3 and then for 10 seconds if that doesn't work, disconnect all jackets meaning all usb connection ports connected in it. Remove them, then turn on your ps3 see what happens (without using the controller), then disconnect the ps3 cord that connects to your extension cord or jacket and plug it back in. Try it again. Then again with the controller could try. Try disconnecting other ports such as other stuff like as listed, Irons,Fans, etc.           !!!!!!DON'T USE TOO MUCH POWER!!!!
The Same thing happened to me on my Wii though.
If nothing works call Customer Support (SONY)
May 30, 2009 | Sony PlayStation 3 40GB System
Red flashing light and PS3 won't work
I have had this same probelm unfortnaully .. It sux , and after trying alot of different things and reading , and talking to sony themselfs seems only fix is $150 repair or a new playstation :( . . Have you noticed your fan is just loud and has like 3 stages of loudness? Thats what mine did , and i got the red flashing lights if not loud then anthor device in your playstation has stopped working sorry to say
Feb 02, 2009 | Sony Playstation 3 (PS3) Console
Sony PS3 PlayStation 3 Game Console 40gb Logo
342 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
