Question about Nokia 6300 Cellular Phone
Nokia 6300 won't turn on or charge, battery is dead
My Nokia 6300 won't turn on or charge, i also have Nokia C1. Both phones take same battery, i swapped over the battery and it worked on Nokia 6300, so it is not problem with the phone but with the battery. Does anyone know how to fix the battery?
Posted by Hamza on
Michael Lawing
    Master:
  • Nokia Master
  • 545 Answers
It probably needs replacing. Batteries are generally the first component to go faulty on cell phones. It might be swollen -- this is a clear indication that the battery is useless.
Posted on Nov 15, 2012
5 Related Answers
micromaster
micromaster
  • 3614 Answers
SOURCE: Nokia 6300 -Wont switch on , only has blue lights
your cp having a defective lcd now. it need to be replace and send it to repair center,
Posted on Nov 05, 2008
Anonymous
  • 21 Answers
SOURCE: Nokia 6300 on off switch problem
the switch button is or maybe broken
the best way is to send it right away to the nearest service center
Posted on Apr 27, 2009
Anonymous
  • 50 Answers
SOURCE: nokia 6300 dead
Your battery is completely dead the best thing to do is by another battery.
Posted on Jul 01, 2009
Anonymous
SOURCE: problem with charging nokia 5800
buy new mobile .........
Posted on Feb 28, 2010
Anonymous
  • 5 Answers
SOURCE: My Nokia N95 8Gb is dead now. It had turned off
just buy anew phone..
Posted on Mar 23, 2010
NOKIA C1 01 PHONE BATTERY LOW PROBLEM WHEN BATTERY IS FULL CHARGE.
Hi Please clean the Center terminal of the battery as well as the battery connector of the phone.That's all you have to do and this is the first aid.Sometimes battery low indicates when the center terminal has short/ not contact to the phone properly. Thanks for visiting fixya...Good luck
Sep 13, 2011 | Nokia C101 Cell Phone
I recharged my 6300 battery and now, when I switch the phone on, the screen flashes twice and the phone switches off. A couple of weeks ago the keypad wouldn't work but it came right so I didn't...
some of the nokia 6300 mobile as the same problem after changing there battery your battery does not fit to your model mobile phones change the battery or make your battery to fit to your mobile then it will be back as good it was.If you have same problem means take out your memory format your memory card.
Jun 10, 2011 | Nokia 6300 Cellular Phone
Nokia 6300 showing charging but not increasing battery charge level
Could be possible that the charger or the battery by itself is faulty as many of them gets reverse polarity in the cell. It will be ideal to swap and check with the same type from a friend which is most easy as many are around so as to confirm before you can invest.
Please clean the battery contacts and the terminals.
Apr 05, 2011 | Nokia 6300 Cellular Phone
My nokia 6300 can't charged battery & can't open . How to repair ? Please teach me ...
If you experience this type of problem on your nokia then the charging point is faulty u need to change it and if u cant open then u need to flash the device from your computer thanks .
Feb 07, 2011 | Nokia 6300 Cellular Phone
Nokia 6300 charging not supported
When your phone shows charging not supported. First, you need to try a another battery on the phone, if it says the same thing, then try to use another charger, and if it shows the same thing, then you need to fix the charging port of the phone.
Before you do that, test, your battery and charger on another phone to see what happens, if they both work fine, then you need to fix the charging port of the phone.
Take care and good luck
Oct 13, 2010 | Nokia 6300 Cellular Phone
My nokia 6300 phone won't turn on
it is not a issue with battery or sim card. It can be issue with display or software. Go to nokia showroom and check with them once.
May 10, 2010 | Nokia 6700 Classic Cell Phone
Nokia 6300 Switching off
Purchasing a new phone is easy and everyone is always in a hurry to use new phone but never go through the manual properly. You did the same you didn't put the battery on charge for 24 hours. Now to check your phone take another charged battery for nokia put it inside your phone and start it. It will deffinetly work. In order to revive your dead battery keep your battery on charge while the phone is switched off for minimum 24 hours. If it gets revived its ok or else purchase a new one.
Jul 25, 2009 | Nokia 6300 Cellular Phone
6300 Won't turn on
my nokia 6300 could not open when i switched on it, its side light on but the display is blank
Feb 26, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
339 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
