TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
What do you mean by "changed the resolution"?
SOURCE: ti 84 plus silver edition language change
The easiest way to fix this is through the Apps menu. Hit the apps key, then scroll down until you see any language(espanol, Deutsch, etc.). It should give you the option of switching to either that language or restoring to English. I just tried this on a calculator that was set to German. I hit Apps and scrolled down until I recognized the option for Spanish, and it still worked. It let me switch back to English.
Hope this works for you.
SOURCE: I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
SOURCE: I have issues turning on my TI-Nspire using TI-84 Plus SE keypad
i would say use the normal key pad or send it in to T.I to fix.
SOURCE: TI-84 Plus Silver Edition FROZEN
The first part of the post is inserted for completeness (and in case you need to readjust the scree. You can just skim through it.
Part A or B will reset the memory. Please read the whole post before attempting the procedures described here.
The first diagnostics you should perform are:
Here are some more procedures to perform
in the order they are presented. Please
read the post till the end.
A
B.
C.
This
step requires the reinstallation of the system. So
to use it you must download the TIConnect 1.6 software from
education.ti.com. You must have the TI USB SilverLink or the TI Black
serial cable ready.You must be connected to the Internet.
If the message "Error! Press any key to
turn unit off. Then turn unit back on."
appears on the graphing calculator, quickly, remove one battery from the
calculator and reinstall it while the transfer is taking place.
You
have several ways to connect the calculator
