Question about Sanyo SR-4911M Compact Refrigerator
Sanyo sr-4911m.its too cold inside.snow build-up on top of back wall inside tried
Tried to ajust temperature but no success ,any idea please
3 Suggested Answers
Anonymous
SOURCE: Sanyo counterhigh refrigerator model SR-4911.
remove shelves and insert keg.
Posted on Feb 03, 2010
sur singh
  • 51 Answers
SOURCE: My Sanyo SR-4911m refrigerator does not cool.
make on thermostate and check compressure working or not
Posted on Dec 01, 2010
canwoodjc
Canwoodjc
  • 3301 Answers
it shouldn't be gurgling, has it been laid on its side at some point? anyway,, sounds like it has air in the system,, unplug it and let it stand upright for 24 hours, if the problem still persists,, it may need to be charged, the compressor getting hot is normal , if its very very hot, its because its running constantly trying to cool the unit
Posted on Jul 04, 2011
What is the coolest temp. for Sanyo SR-LV209f... 5 or 1
On any refrigerator that I have owned, the higher the number the cooler the temperature. Thus 5 would be the coldest temperature setting. If you set it too cold, items will freeze in your refrigerator.
Aug 14, 2015 | Sanyo Refrigerators
Sanyo sr-4433s not cold broken while removing ice
There is a sensor wire in the vicinity of the ice-box... If you've forcible removed the ice build up... you may well have damaged this and hence the thermostatic wire will need replacing.
May 15, 2014 | Sanyo Refrigerators
My Sanyo SR-4911m refrigerator does not cool. Compressor seems to turn on when termostat is turn from off position to on position. However, compressor gets really hot and gurgles, but does not cool the...
Jul 04, 2011 | Sanyo SR-4911M Compact Refrigerator
Fridge wont work
The fan shuts off when you open the door. It's controlled by the door switch. open the door and look for the door switch, push it in and the fan should come on.
Sep 09, 2009 | Sanyo SR-4911M Compact Refrigerator
Ge mini fridge seems to be overheating
the unit should have heat coming off the condenser coils on the back. some of the units have a little fan motor to help cool the condenser. make sure there is plenty of space for air flow around the unit, as this is crucial to normal operation.
Aug 25, 2009 | Sanyo SR-4911M Compact Refrigerator
Not cooling....
Sounds like you checked for the proper items, fans to move cold air, etc. and if stuck in defrost mode. If the compressor is running you would have to be cooling unless... the refrigerant has leaked out. And that is basically a bad thing. If in defrost cycle the compressor would stop while defrosting soooo it's looking like the refrigerant is gone. Can you take the back interior panel off to see if the coils have a full frost pattern?
Jan 04, 2007 | Sanyo SR-4911M Compact Refrigerator
Sanyo SR-4911M Compact Refrigerator Logo
41 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
David Soto
David Soto
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
