SOURCE: i need to flush my bios.forgot password. Sony vaio pcg-7g1m
Try This:
Reseat the CMOS battary:
How to Change/Reset a BIOS password
Posted on 30 December 2008
Tags: Tech News, Tutorials
If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
SOURCE: the fan of my sony vaio model pcg 3c2l stops
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
