Could you give us some details as to how it's not working? What lens(es) are you using? Does it work properly in manual mode?Could you give us some details as to how it's not working? What lens(es) are you using? Does it work properly in manual mode?
Nikon F3 auto mode fault is shutter staying open and only closing when dial moved to either side of speed dial. manual mode its ok.Nikon F3 auto mode fault is shutter staying open and only closing when dial moved to either side of speed dial. manual mode its ok.
and you can heard some noise like timer start then it stopped to lock up the shutter.and you can heard some noise like timer start then it stopped to lock up the shutter.
You can't post conmments that contain an email address.
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Hi kathlag96, page 43 of the manual state that Auto ISO works in the Vari-Program modes. Page 88 item 7: explains Auto ISO does not work in the P, S, A, M modes
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Yes. The SB-600 instructions don't mention the D60 because the SB-600 came out before the D60 existed. Bear in mind that the D60 does not have a commander mode so you can't use the SB-600 as a slave.
Basically, as far as the SB-600 instructions are concerned, just pretend that you have a D40.
nikon usa still provides parts for Nikon f3 cameras. You can order by phone at : 310-414-8107. They are very helpful and take great care of Nikon owners,
Nikon Coolpix s3 powers on OK when switch is on auto mode, but when switched to "Scene" mode cannot shoot, switch back to auto mode / movie mode, or turn off. If power is turn on when switch is in "Movie" mode, everything is OK. Help!
dr rajeev jain [email protected]
I was having the same problem with my D40... but I read your post, tried switching the 18-55 lens to manual, then back to auto, and it seems to be working fine now. Hmmmm... think maybe there's a circuitry issue with the lens?
