SOURCE: xerox Phaser 6180
Hiya -
Is there an option on this printer to default all jobs to black & white printing only?
Many thanks, A.
SOURCE: Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
SOURCE: Xerox 6180 MFP makes copys that are blurry and
I think attracting scanne(copier) be cleaned is probably dusty inside
SOURCE: Xerox Phaser 6180 keeps saying load papertray with
When you adjust the length guides there are 3 little white switch actuators that eith do or do not actuate three little white switches inside the machine which tell the machine the position of the length guide.
For 11"paper only the bottom one should be sticking out to actuate the bottom switch inside the machine.
Make sure they are intact and that no torn off piece of paper is holding a switch actuate.
If you rmove the tray with a flashlight you can see the three switches inside the machine on the right about 2/3rds of the way back.
They should move freely but they do not go click when you press on them
I don't see anything that monitors the width of the paper in the tray..
If all that works, time to call service.
