This machine is the replica of the 3M Thermal Transfer Machine presently available from Technical Tattoo Supply; it is practically identical to the 3M model in all aspects. I should further add that the light goes off once the stencil has been made, it is the fan that fails to shut off regardless of how hot or cool the machine actually is at the time. The fan simply continues to run. I have already replaced the 2 black switches that appear to control the fan/light adjustments, but that changed nothing as the fan simpy continues to run. Any help or ideas would be greatly appreciated. Thanks!!!l
SOURCE: Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
SOURCE: thermofax machine repair
Not really sure what you are asking? Is it a thermofax that is making noise that you use to make transparency with. Or is it transparency making? I never worked on a transparency maker in 20 years of office machine repair... What is it? Is a old machine? If it is that old it may be time to replace it....
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
SOURCE: I have a 01' New Beetle my cooling fans come on
I finally fixed the problem. It wasn't the Water pump, or the Fan switch or the Green Temp Switch or the Fan Control Module but the "BLACK" NOT White, 2 Pin Thermal Switch 112c" It does sit in between 3 collant hoses where the upper radiator hose comes together with 2 smaller hoses. Kinda looks like a peace sign and in the center sits the 2 Pin Thermal Switch. It's not a AC Cut off switch which even the dealer tried to sell me and which I actually ordered from ECS tuning. The AC Cut out switch is "White" and even thou looks the same in size and form will not fix the issue. I was able to read the part number off the old switch which is 357919369F which when I looked it up on the ECS tuning web site did bring me to the right switch. Black with a green stripe on the top rim. I ordered that baby and it came in yesterday. Took the White switch out and put the Black switch in and guess what the fans no longer turn on when the ignition is in position 2 and now the fans come on when they are suppose to and don't sound like a jet engines afterburner. Simple 20 dollar part solved the problem. I think a lot of people are getting the wrong part from the dealer since this part is very hard to find. Everyone I asked wanted to give me that white sensor AC cut out switch but that isn't it. Here is the link to the correct switch hopefully it will help someone avoid a bit of frustration. http://www.ecstuning.com/Search/357919369F/ES248948/
